So What do you Recharge your AC with?
Old Apr 12, 2006
thorough's Avatar
thorough is an unknown quantity at this point
my Girlfriends dad says he can do with freon but i was sure they didnt use that anymore. i have seen kits on sale to recharge it but im not sure what to use. i tried searching this forum and couldnt find much. my 01 civic LX starting blowing warm air when the AC was on a while back. Thanks in advance.
Old Apr 12, 2006
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
r134
Old Apr 12, 2006
Ichiban's Avatar
Ichiban is an unknown quantity at this point
The new cars use R-134a refrigerant. And also you need to add refrigerant oil. Also if you are blowing warm air you probably have a leak somewhere. Go check it out first before you waste money on charging the system just to have it leak out.
Old Apr 12, 2006
thorough's Avatar
right on. the air kind of gradually warmed up over time so i dont know if that means its a leak. i guess i will have someone check it out.
Old Apr 12, 2006
dp_yz713's Avatar
my truck used to do the same, actually both my trucks did that over time. just keep refilling, if you do it yourself its not that expensive. i usually put a can or two a year
Jul 14, 2015 03:39 PM
beeemerdude
Jul 10, 2015 09:22 PM
gearbox
Jan 31, 2005 02:29 AM
Voiceofid
Feb 18, 2003 10:47 PM
astr033
Jul 17, 2002 11:28 AM
