Need help clearing headlights
Old Feb 24, 2002
DrOpPeD2k2CiViC's Avatar
DrOpPeD2k2CiViC is an unknown quantity at this point
I want to clear my headlights but i also dont want to mess them up. I was wondering if someone in the North Carolina area would help me do this i would pay you some money for the help. email me at jbmoney19@aol.com if u would like to help
thanks,
Justin
Old Feb 24, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
be brave and do it your self...
just give your self a weekend to do it. just in case you have to take them apart again and redo them.
Just take this advise:
Once all the clips are off, take a small flat screw driver and slowly pry the lense away from the back.
If you are care full about it, the black stuff won't be a problem.
To do things right, take your time and clean out all the black stuff. Scrape it all out of the groove and off the clear lense. Might want to wear some latex gloves while doing that.
then put a bead of sealent in the groove, put the pieces together, and put a generous amount of sealent all around the edges.
A good way to test for leaks after it has dried:
Get a shopvac or something like the sort that has an exhust port and hose. Take out the main head light, put the rubber seal back on, and put the hose up to the hole and blow air into the unit. (Make sure the air is clean first).
Now take a solution of soap and water (2part water - 1part soap) and slowly apply it to the sealed edges.
What will happen, with the pressure inside the headlight, any air escaping will start to blow bubbles at any hole in the seal.
Have fun!
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
brash99
Sep 29, 2015 08:42 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
