why wont my rsx injectors fit??
first off wtf!
ok, they fit in the ports but i cant get the nuts on the studs to hold the rail. what did you guys do?
and PLEASE help me and tell me what numbers and letters are on ur injectors so i can see if mine are realy rsx-s injectors.
thanks and pics upon request when i find the camera!
you gotta pull the studs out and either get longer studs or just use a couple bolts to hold the rail down. if you compare the stock injectors to the RSX injectors, you'll see that the RSX ones are physically longer.
yea they are physically longer, but the problem is do i have rsx or rsx-s or maybe some other k-series or w/e u know?
cus im pretty sure on the e-manage i have to type in the flow rate of them so i dunno if they are 360 or 400 or w/e the 2 are.
i was under the impression that rsx and -s had the same injectors.. i dont know though..
and they're 310 or 320's.. stock is like.. 240? i know i may be off by like.. 10 or so on each one of those flowrates
7thgen Power Maker
Originally Posted by ncirom2003
yea i forget the exact numbers, im pretty sure they are 2 different ones tho.
You will more than likely throw a MAP/BARO CEL because of the injector correction factor being too large. You will have to end up going 270 > 310 and tuning some of the fuel out manually.
oh, eh ill leave that to the tuner guy.
so k20a2 and a3 use same injectors?
I didnt realize the rust a had on there.. uhm yeah don't overtighten them if you aren't using spacers/washers. Just tighten em up snug so you dont crack the injectors.
Anybody try to put a rubber or metal bushing in the empty space on the new bolt? Probably would not accomplish anything but aesthetics. Just an idea. Do not have them so really cannot play with the idea.
7thgen Power Maker
i just put the plastic washers from stock back, they didnt do anything though lol. i couldnt hold the washers so after 2 tries i just put the bolt in hahaha.
anyways, anyone know how i can tell if i have a2 or a3 injectors???? i really need to know. i have a pic so i know what the numbers are on them.
GritzNGravy
Aug 19, 2015 03:03 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
Green02civic
Jul 27, 2015 10:48 PM
EM_WON
Jul 22, 2015 06:49 PM
