why wont my rsx injectors fit??
Old Mar 29, 2006
ncirom2003's Avatar
first off wtf!
ok, they fit in the ports but i cant get the nuts on the studs to hold the rail. what did you guys do?
and PLEASE help me and tell me what numbers and letters are on ur injectors so i can see if mine are realy rsx-s injectors.
thanks and pics upon request when i find the camera!
Old Mar 29, 2006
you gotta pull the studs out and either get longer studs or just use a couple bolts to hold the rail down. if you compare the stock injectors to the RSX injectors, you'll see that the RSX ones are physically longer.
Old Mar 29, 2006
ncirom2003's Avatar
yea they are physically longer, but the problem is do i have rsx or rsx-s or maybe some other k-series or w/e u know?
cus im pretty sure on the e-manage i have to type in the flow rate of them so i dunno if they are 360 or 400 or w/e the 2 are.
Old Mar 29, 2006
i was under the impression that rsx and -s had the same injectors.. i dont know though..
and they're 310 or 320's.. stock is like.. 240? i know i may be off by like.. 10 or so on each one of those flowrates
Old Mar 29, 2006
ncirom2003's Avatar
yea i forget the exact numbers, im pretty sure they are 2 different ones tho.
Old Mar 29, 2006
tfnaaf's Avatar
BLDNPSI Mod
like posted above, you need longer studs and some washers/small spacers. As i recall about 1/4"-3/8" longer
Old Mar 29, 2006
dezod's Avatar
7thgen Power Maker
240 > 310,
You will more than likely throw a MAP/BARO CEL because of the injector correction factor being too large. You will have to end up going 270 > 310 and tuning some of the fuel out manually.
Old Mar 29, 2006
ncirom2003's Avatar
oh, eh ill leave that to the tuner guy.
so k20a2 and a3 use same injectors?
Old Mar 30, 2006
djmota's Avatar
nope a3 injectors are 270cc. I got a set of those coming to help out my NA tuning.
Old Mar 30, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
I didnt realize the rust a had on there.. uhm yeah don't overtighten them if you aren't using spacers/washers. Just tighten em up snug so you dont crack the injectors.
Name:	100_8012 (Medium).JPG
ID:	65468   Click image for larger version
Name:	100_8013 (Medium).JPG
Old Mar 30, 2006
Toaster's Avatar
Toaster is on a distinguished road
Anybody try to put a rubber or metal bushing in the empty space on the new bolt? Probably would not accomplish anything but aesthetics. Just an idea. Do not have them so really cannot play with the idea.
Old Mar 30, 2006
dezod's Avatar
7thgen Power Maker
I had one in my 7thgen.
Old Mar 30, 2006
djmota's Avatar
a stack of washers is a tuners best friend. instant spacer.
Old Mar 30, 2006
XSRCivic's Avatar
^^ agreed.. laziness is the tuners worse enemy (my enemy shown above)
Old Mar 30, 2006
dezod's Avatar
7thgen Power Maker
GHETTO!
Old Mar 30, 2006
Originally Posted by dezod
GHETTO!
lol.. thats what i did.. it works tho..
Old Mar 31, 2006
ncirom2003's Avatar
i just put the plastic washers from stock back, they didnt do anything though lol. i couldnt hold the washers so after 2 tries i just put the bolt in hahaha.
anyways, anyone know how i can tell if i have a2 or a3 injectors???? i really need to know. i have a pic so i know what the numbers are on them.
Old Mar 31, 2006
djmota's Avatar
[QUOTE=dezod]GHETTO! [/QUOE]
you can take the man out of the ghetto, but you can't take the ghetto out of the man.
GritzNGravy
Aug 19, 2015 03:03 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
Green02civic
Jul 27, 2015 10:48 PM
EM_WON
Jul 22, 2015 06:49 PM
stvpagn
Jul 9, 2015 09:59 PM
