m3 mirrors w/led's turn signal
Old Mar 25, 2006
neocivic01's Avatar
the Rage
neocivic01 is an unknown quantity at this point
Arrow m3 mirrors w/led's turn signal
has anyone installed these before? putting the mirrors on shouldnt be a problem but i dont know where to splice in with the turn signal wires. any help with this would be AWESOME. thanks.
Old Mar 25, 2006
myinca's Avatar
myinca will become famous soon enoughmyinca will become famous soon enough
are they power or no? if power u may have to mess around with the wire combinations to get them to move correctly( there is a DIY here somewhere on what color wires to hook up, its a little off but u will have most of the wiring done). for the turn signal, some people just ran a wire up to the bulb by the headlight, i found the turnsignal wires under the steering column. just put ur blinker on and poke around with a volt meter till u find out which wire it is. if u still cant find it on the DIY pm me and i will tell u which wire it is on mine when i get back in town( i have an 01 ex coupe)
Old Mar 25, 2006
oh man i just explained this to someone. Okay, first just find the ground and then one at a time hook up each power wire to see which one lights up the led. You can just use a battery for this. Once you know, you can tap the wire to either parking light red wire (going to front corner bulb) to turn on with parking lights, or green wire if you want it to flash with the signal. then hook the ground to the black wire. if you want the led to flash AND stay on with parking, hook one wire to green and the other to red (no ground).
the m3 might also have two led so you can wire it so one color stays on and one just flashes or whatever.
Old Mar 25, 2006
neocivic01's Avatar
the Rage
thanks, ill try to figure it out. thanks for the help.
Old Mar 25, 2006
RHCP0801's Avatar
http://www.7thgencivic.com/forums/sh...d.php?t=215678 heres the DIY for the install of the mirrors if you want, not the light up ones tho, just figured id help out a little
Lopes101
Jun 7, 2015 08:04 PM
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
