Coilover Problems! Help plz!
Old Mar 25, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
I just installed my Progress coilovers. But everytime I turned, the front springs would move and throw my alignment off. I went to get an alignment, and the guy said maybe it wasn't installed properly. I did everything according to the manual and double checked. Anyone have any idea what could be causing this, plz help me out. Thx!
bump
Old Mar 25, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
WEll you alignment is getting trown off cause you ajusting it, thats obvious. But an easy way is kind of what i did. mi car is lowered but not slammed. the front is 24 inchs to the center of the light and the rear is 25 to the center of the rear end. Bassiacally i took a tape messure and mesured from the center of the wheel well to the outter ege of the rim. and ajusted till i had 4.5 in the front and 4.75 in the rear. then i added my camber ajustment kit and took it to get allighned. Havent touched it since.
Started like:
ended like:
Old Mar 26, 2006
fallout's Avatar
LOL. Thx, but that's not the problem. When i said turn, i mean by driving and making left and right turns....and not adjusting the height. It's making noises and i think the springs are moving when I turn from a stop. Then my alignment would be thrown completely off. This doesn't happen if i go 20+ mph. This is freaking me out. I have no idea what's causing this. Any help is appreciated.
Old Mar 26, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
sl0wEM2 has a spectacular aura aboutsl0wEM2 has a spectacular aura about
It could be the guy that did your alignments fault? or post pics to see if it's installed properly.
Old Mar 26, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
**** i hope i don't run into this problem when i install mine. you did use the stock bearings right? try jacking the car up and make sure they fall in place when you lower it back down. is it doing it on both sides? I'm not sure whats all that has to be used from the stock parts. but it seems like the bearing isn't tight enough on the spring which causes the whole bearing to move and no do its job. i hope you can fig this out be fore i get mine in
Old Mar 26, 2006
Why not just take some white out and go threw every nut and bolt make sure there tourqed and then go for a drive. see if ones moved.
Old Mar 26, 2006
vacivic2005's Avatar
vacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the rough
how does the progress ride btw.
Old Mar 26, 2006
djpolanco's Avatar
djpolanco is an unknown quantity at this point
coil over question
i have a problem i have 2001 coil overs but i wana know if they will fit my new 2005 ???
Old Mar 26, 2006
fallout's Avatar
Every nut and bolts are torqued. I did use all the stock parts as the manual stated. I did jack the car up, everything looks good, but it does look like something is missing. I'm still waiting for supermex's response on this issue.
Old Mar 26, 2006
what do you mean somethings missing?
Old Mar 27, 2006
fallout's Avatar
Ok i used the factory strut bearing and the upper strut mount. That's the only things the manual said to use from stock parts. Is there anything else i nees to modify or use?
Old Mar 27, 2006
Diablo's Avatar
thats all Ive been told that needs to be done with these coilovers. do you have everything supermex has shown here?
http://www.7thgencivic.com/forums/sh...light=progress
Old Mar 27, 2006
fallout's Avatar
Omg his setup looks exactly like mine. I dunno what the hell is wrong!!
Can it be that i torqued everything too tight?
Old Mar 27, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
I know an alternative, trade me for my D2 full coilovers. Have you contacted progress or dezod about the problem?
Old Mar 27, 2006
fallout's Avatar
^^^ hahaha thx for the offer, but this thing handles like a dream!
Except for the spring clanking and alignment ****, i love how this thing handles.
Old Mar 27, 2006
Does the spring need to be indexed?
Old Mar 27, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
Yea, D2 coilovers handles like dream as well. I just want to go lower!!!
Old Mar 28, 2006
Diablo's Avatar
^^^^^If it doesn't have to be indexed maybe you should make sure the top cap is in the same position as it would be on the stock struts. with the indexed mark to the front, its worth a shot. i hope mine get here this week that way i can post pics of the install.
Old Mar 29, 2006
fallout's Avatar
^^^ You lost me there man.
Old Mar 29, 2006
Diablo's Avatar
never mind I have been doing some searching its got to be on the right way. maybe you bearings are shot.mine should get here either this week or next. I'm going on my 3rd week of waiting. ill post pics step by step when i do my front install and see if you left something out
Old Mar 30, 2006
K/Turbo's Avatar
Also known as rlmedin1.
K/Turbo will become famous soon enoughK/Turbo will become famous soon enough
When I installed my B&G Coilovers I had to buy 2001 upper mount bearings. That's because I had a 2005 and the coilovers were made for 2001.
The 2001 is shaped like a circle were it meets the coilover and on the 2005 it was shaped like a triangle if I remember correctly. Since they are not shaped alike they will not fit correctly. Maybe that's the problem. Hope this helps.
Old Mar 30, 2006
fallout's Avatar
Huh. That's something to think about. I thought the only difference was the mount holes. I have a 2004, so this could be the problem.
Old Mar 30, 2006
Diablo's Avatar
you wouldn't happen to have any pics of the 05 bearing. i just want to see the difference
Old Mar 31, 2006
fallout's Avatar
Yeah. A lot of people says it's the bearing and i think this is surely the problem. Mine is sitting pretty lose cause i have a 2004. If we can see the difference between the two, then we can solve this issue once and for all.
Old Mar 31, 2006
K/Turbo's Avatar
I don't have any pics of the 05 bearing. Check this link out. http://gametrax.net/b+g/ This link has pics that compare the differance how the 2001 upper bearing to the 2002-2005 bearing and explains why 2002-2005 will not seat properly on a coilover made for a 2001 Civic.
If your coilovers were made for the 2001 and you have 2002-2005 then you'll need part #10 and #11 and quanity of two for part #9 from a 2001 Civic. You can get them at your Honda dealer or order them online at http://www.hondaautomotiveparts.com. Hope this helps.
Name:	2001 bearing.gif
Old Mar 31, 2006
Diablo's Avatar
thanks. this must definitely be the problem i better start ordering my 01 bearing and spring cap. An spend $92 more.
Old Mar 31, 2006
fallout's Avatar
ok this is absolutely the problem. I did jack up the car, and i've seen that the bearings sitting on top of the springs is lose. There is a lot of room for the bearings to move around.
I mean, when i order this, it clearly states that it was made for 2001-2005. I guess we're gonna have to take it out with Dezod on this one.
So we need parts #9, 10, and 11?
Looks like we just need #9 tho. We know the bearings are different. Is the strut mount different too?
Old Mar 31, 2006
dezod's Avatar
7thgen Power Maker
This is probably 99% correct. These coilovers need to be indexed otherwise the clicking and popping will occur. That has been the #1 mishap on installs of these coilovers.
Furthermore, if you have a metal bearing in the 04-05 models, you MAY need the plastic version, which is Progress Part # 66.0102 or Honda # 51726-S5A-004, which is about $14.
http://www.hondaautomotiveparts.com/...VIN+Number+---
Old Apr 1, 2006
fallout's Avatar
Ok i'll give this a try tomorrow. Thx guys.
What a waste of 3 hours. The cap is sitting the right way and the noise is still there. I'm starting to think it's the bearings now...?
Myredjonda
Apr 14, 2015 07:00 PM
luukass
Dec 14, 2001 06:27 PM
deception420
Dec 6, 2001 02:31 PM
WhopSi
Nov 29, 2001 09:59 PM
Flatlander
Nov 16, 2001 05:38 PM
