do resistors add up?
Old Mar 23, 2006
if i have 3 resistors each 22 ohm, and i hook them all together, do i have 66ohm total resistance?
Old Mar 23, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
In sieres yes
If you put them in parralle they dived by there squares
Old Mar 23, 2006
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
Series=66
Parallel=7.33
Old Mar 23, 2006
you can check that with an ohm meter
Old Mar 23, 2006
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
this is why i couldn't be an electric engineer
Old Mar 23, 2006
TheMadBomber's Avatar
TheMadBomber is an unknown quantity at this point
You can also get 33, by paralleling two (for 11 ohms), and putting them in series with the other.
--TMB
Old Mar 23, 2006
dk1021's Avatar
dk1021 is an unknown quantity at this point
Wow .. i just noticed I forgot all my electronics knowledge!
Old Mar 23, 2006
lol so did i. most noob question ever but i had a feeling it added up, common sense i guess haha
Old Mar 23, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
so are they in series or are they parallel? ans what are they for.
Old Mar 23, 2006
well i'm being lazy. i have a gauge cluster with 30+ leds wired. 4 leds in series and each set of 4 wired in parallel. this is fine without resistors for 12v, but for 15v (running car) i need 68 ohm resistance on the power lead. and i should just go buy a single instead of sticking a bunch of 22 ohm together.
Old Mar 23, 2006
MajinB's Avatar
lol probably best. help your cost be down when you make them too
Old Mar 24, 2006
CraigW's Avatar
A 1/2 Watt resistor may run hot in that situation, You may need a higher Wattage rating.
Good info here ----> http://www.lsdiodes.com/shop/
Old Mar 24, 2006
diskreet's Avatar
This is easy. Its the complex differiential equations that gets most people.
(I am not an EE but I am a Computer E student and so far the first 2 years are the same 'cept i get programming classes)
here are 2 ways to find resistor value of resistors in parallel:
say you have R1 || R2 (R1 in parallel with R2)
R[equivalent]=(R1*R2)/(R1+R2) This only works for 2 resistors
R[equivalent]=1/((1/R1)+(1/R2)+(1/R3)+...) Follow this pattern to add up any amount of resistors in parallel
Capacitors are the opposite:
In parallel C[equivalent]= C1+C2+...
In series C[equivalent]=1/((1/C1)+(1/C2)+...)
Hope that helped
Old Mar 24, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
P=V^2/R...
so the power on the resistors are 15V squared 225 and divide that by 68 ohms...equals to 3.3W...this is the minimum power rating of your resistors..all combined....it will burn/turn black...
Old Mar 24, 2006
diskreet's Avatar
P=IV too.
Old Mar 24, 2006
i'm lost. i have bunch of 4 led series hooked in parallel. each led has forward volt 3.4v and 20ma current. Now hooked to a 12v the circuit is fine, but i need 15v since the alternator puts out more. according to what i've calculated, thats around 68ohm needed for 4 leds. i thought it wouldn't matter since everything else is in parallel. can't i just add 68ohm resistor to the beginning of the circuit?
Munzy
21
Oct 7, 2015 07:48 AM
Islesfan
Sep 29, 2015 03:42 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
General DIY
Sep 25, 2015 08:02 PM
hatch90
Sep 3, 2015 08:45 AM
