problem w/my nos
Old Feb 21, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
problem w/my nos
im having problems when my system is activated.i feel a boost and then it slows down and the engine starts lagging.any one have any clue why?
Old Feb 21, 2002
bottlefed's Avatar
bottlefed is an unknown quantity at this point
mine does that too but it starts lagging fromthe start now like it's fludding it. don't know what's wrong but i have to drop off my car at the shop for a day so they can look at it
Old Feb 21, 2002
civichx81's Avatar
where did you mount your fogger nozzle? maybe its too close?i dont know whats up w/ this..
Old Feb 21, 2002
black's Avatar
black is an unknown quantity at this point
Hope your rice-rockets gets beter soon B.
-=- peAce -=-
Old Feb 21, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Have either of you hollowed out or removed your catalytic? That could be one of the problems.
Just my opinion.
Also, remember the amount of maintenance that goes into a car that is using N2O. You need to change your spark plugs frequently, etc. etc.
Old Feb 21, 2002
silvervtec01's Avatar
silvervtec01 is an unknown quantity at this point
just out of curiuosity, what does Hollowing out ur CAT do anyways....and also, wouldnt it just be easier and more productive HP-wise to completely ELIMINATE the CAT by removing it?
Old Feb 21, 2002
mohawkboom's Avatar
Well.. How often do you change your oil.. How often you firing NOS,.. for how long at a time?...You may have either Ignition probs (burnt plugs) Or possibly compression loss and blow-by. In which case.. new rings are needed. a Third possibility is that your Jets need re0-adjusting and your fuel ratio needs to be a bit more lean... If you run too rich, you're putting alot of carbon waste in your cylinder which will overtire wear your rings and cylinder walls. Exhaust valves..and clog your Catylitic.
Check your plugs first...if they're really dirty and or pitted... get colder plugs. (any cheap spark plugs will do) Change them every other oil change (at $2 a plug it won't kill you). And lastly.. if that's not the prob.. get your compression checked.
Cheers
Mohawk
VTECnique
Jan 6, 2002 02:47 PM
black
Dec 29, 2001 10:06 PM
SugarRay
Dec 13, 2001 09:58 AM
MooCoW
Nov 15, 2001 10:58 AM
