Question for those who has turbo installed
Old Feb 26, 2006
hydroflare's Avatar
hydroflare is an unknown quantity at this point
I just got my turbo done on my 04 civic ex. I have a check engine light for primary o2 sensor not reading. I think it is code 0143. I have the primary o2 sensor mounted near the top of the down pipe. Is it in a bad location and not reading right or something else is wrong? It was working fine before turbo. let me know u guys
Old Feb 26, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Well aside from the obvious question of is it plugged in, did you drop it when you took it out or do anything that could have otherwise potentially damaged the sensor?
If its too close to the turbo, it may be too hot and it may not like it, or its too hot and burned out the sensor.
Old Feb 26, 2006
hydroflare's Avatar
no physical damage, never dropped it, stored in a box during install. check engine light came on before driving it out of garage to test boost.
Old Feb 27, 2006
tfnaaf's Avatar
BLDNPSI Mod
What turbo kit?
Old Feb 27, 2006
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
It might be too close and getting very hot. I have mine right in front of the oil pan, just before the downpipe goes below the oil pan. Good luck
Old Feb 28, 2006
hydroflare's Avatar
its a xspower turbo from ssautochrome (ebay stuff). it is a custom turbo kit that i had assembled together. i would say my o2 sensor is nearly in front of my oil pan too. i think maybe the wire went bad or something from taking it off with the socket. so what type of fuel management are you using Pedro?
Old Feb 28, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
what civic is that?
Is your engine d16?
Old Feb 28, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
o2 sim might help, not sure though
Old Feb 28, 2006
hydroflare's Avatar
sorry i am not on this forum much. would u like to tell me what o2 sim is or what it means?
I have a 04 civic ex (D17a2 engine).
xs power T3 turbo
xs power external wastegate
xs power bov
obx turbo manifold (chopped up like crazy cause it doesnt fit right)
emanage (injector harness & ignition harness)
rsx fuel injectors
7"x20" intercooler
custom 2.25" turbo piping
apexi auto timer
i think total in parts is $1900 without exhaust system.
i think it is running 8psi right now, but i havent floored it cause i havent finished tunning.
Old Feb 28, 2006
tfnaaf's Avatar
BLDNPSI Mod
look at my signature ^^^^ 5 post
Old Feb 28, 2006
turboengnr's Avatar
DONT PANIC
where are you from? Your setup sounds like a local guy i helped out at a buddies store. You probably arent, but i thought i would ask.
Anyway, check the wires on the O2 sensor. I know i have had mine off soo many times that i actually stripped the insulation off several of the wires, and they were shorting out. Once i fixed that, all the CEL's went away.
Old Feb 28, 2006
drunkenmagnum's Avatar
the o2 sim should def help, just make sure you dont put the o2 sim on the wrong o2 sensor.
Old Feb 28, 2006
I'm not running a fuel system, I don't need one lol. I don't drive my car anymore and I'm in the process of building my engine and I'm getting the AEM EMS when all of the engine work is done.
Old Mar 1, 2006
hydroflare's Avatar
tfnaaf, it says you have posted 2397 post. i dont see your signature cause my browser is blocking activeX controls.
I am from seattle, wa. my buddy and i worked on the car. thanks turboengnr, i will check the wires cause at one time i tried to tapped into it for the air/fuel ratio but it didnt work on primary o2. i am also thinking it might be because the car is running really rich at low rpms. air/fuel ratio keeps reading at 10.0 on idle. we left the fuel on stock for low rpms but i guess the emanage is doing something to it.
Old Mar 1, 2006
tfnaaf's Avatar
BLDNPSI Mod
LOOK HERE!
Old Mar 1, 2006
hydroflare's Avatar
that looks very interesting. so does it decrease emissions or something? also i notice you were saying to put it on my second o2 sensor. it is my primary o2 sensor that is giving a cel. would it help on my primary?
Old Mar 1, 2006
tfnaaf's Avatar
BLDNPSI Mod
no ....
Old Mar 5, 2006
hydroflare's Avatar
it looks like my o2 sensor is reading out of range. i leaned out the fuel for the lower rpms and the check engine light doesnt seem to come on until i rev a lil higher like 3k rpms. did anybody else have issues with their o2 sensor and turbo?
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 8, 2015 11:16 AM
mikevtec
May 3, 2015 01:36 PM
