Fab question (welding SS)
Old Feb 16, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Can you MIG 304SS?
I've got conflicting opinions. Stainless MIG wire is available, and we've got a welder with an argon tank, so that should be covered.... as long as the settings are right, it should be doable correct? I'm talking exhaust tubing here, its not terribly thick and I don't need pretty overlapping dime welds, just gotta seal it up and not burn holes through it.
Yes or no? Dezod, Gerry, Tom....?
Old Feb 16, 2006
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Yes you can mig 304ss. It's not going to look like a tig weld but it doesn't matter because it's going to be underneaththe car.
Old Feb 16, 2006
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
yes you can...I had some weld work done on my old catback when I had the civic
Old Feb 16, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
yeah that shouldnt be a problem. It feels a lil different than welding with steel wire but its not bad at all to work with. I actually like mig welding stainless. We use it for making big *** grappling hooks for fishing boats and stuff like that.
Old Feb 16, 2006
tfnaaf's Avatar
BLDNPSI Mod
yes, VERY doable ive done it and seen some VERY nice SS manifolds mig'd. I agree on liking to weld SS, its almost easier and seems to always turn out better , could just be my dumb luck too
Old Feb 16, 2006
Jap-Euro Fusion
Thats what I thought.... I couldn't see why they'd sell ss wire and then not be able to do it....
last question.... to weld the new SS DP to the non SS neck on the cat (good ol' emissions) do you use stainless wire or mild wire?
Old Feb 16, 2006
tfnaaf's Avatar
BLDNPSI Mod
Should always use the higher grade metal as in use stainless wire when welding SS to mild
Old Feb 17, 2006
turboengnr's Avatar
DONT PANIC
yes, use the higher grade wire. But remember, when you are welding stainless, use the wire for the grade higher. So if you are welding 304, use 308 wire/rod.
Old Feb 17, 2006
02fpcivic's Avatar
if you are welding s/s to mild steel, try to use 309 wire. It holds up much better.
Old Feb 17, 2006
Jap-Euro Fusion
309 was the wire I had in mind.... there's no issue using 309 for all of it is there?
Old Feb 17, 2006
realitycheck's Avatar
realitycheck is an unknown quantity at this point
The only thing I was wondering about is the pure argon hotter than the 75/25 mix?
Old Feb 17, 2006
02fpcivic's Avatar
75/25 welds hotter, I can run my machines at about 10-20 amps less with 75/25 depending on the materials. The argon will be fine. Id say if you have 304 materials and some mild steel to weld to it just use the 309 for everything. I dont see a problem with that, really.
Old Feb 17, 2006
turboengnr's Avatar
DONT PANIC
if you have a really weak machine (like my little 125v mig) you can use an Argon, Helium, Carbon Dioxide mix. It greatly reduces the amount of power needed to lay the proper bead with the right penetration. And i know my little machine has a hell of a time with stainless when using straight argon.
Old Feb 18, 2006
02fpcivic's Avatar
^ good point.
califcamper
Suspension
Apr 11, 2016 03:43 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
Misfit2613
Jul 30, 2015 09:49 AM
muttleytm
Jul 14, 2015 05:31 PM
