RC 650's
Old Feb 16, 2006
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
RC 650's
When i order these new injectors, can i use the clips that i allready have for the 440's or are they different between the two? I am fixing to upgrade from 440's to 650's. Thanks for your help.
Old Feb 16, 2006
iamboo's Avatar
Retired - SoCal FI Mod
hmmm... clubrsx k20a.org ephatch might be able to help you out a little better than us... i'm sure there are members here that can answer your question but you would probably find it easier over there...
bump for a good question...
Old Feb 17, 2006
andyman97's Avatar
Turbo Guru
Should be the same. Most aftermarket EFI injectors use the same type of clips.
Old Feb 19, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
forgive my ignorance, but why are you upping the injectors?? turning up boost, building the motor, maxed out the 440s, or all of the above??
