Fab question (welding SS)
Can you MIG 304SS?
I've got conflicting opinions. Stainless MIG wire is available, and we've got a welder with an argon tank, so that should be covered.... as long as the settings are right, it should be doable correct? I'm talking exhaust tubing here, its not terribly thick and I don't need pretty overlapping dime welds, just gotta seal it up and not burn holes through it.
Yes or no? Dezod, Gerry, Tom....?
yeah that shouldnt be a problem. It feels a lil different than welding with steel wire but its not bad at all to work with. I actually like mig welding stainless. We use it for making big *** grappling hooks for fishing boats and stuff like that.
yes, VERY doable ive done it and seen some VERY nice SS manifolds mig'd. I agree on liking to weld SS, its almost easier and seems to always turn out better
, could just be my dumb luck too
, could just be my dumb luck too Thread Starter
Thats what I thought.... I couldn't see why they'd sell ss wire and then not be able to do it....
last question.... to weld the new SS DP to the non SS neck on the cat (good ol' emissions) do you use stainless wire or mild wire?
75/25 welds hotter, I can run my machines at about 10-20 amps less with 75/25 depending on the materials. The argon will be fine. Id say if you have 304 materials and some mild steel to weld to it just use the 309 for everything. I dont see a problem with that, really.
DONT PANIC
if you have a really weak machine (like my little 125v mig) you can use an Argon, Helium, Carbon Dioxide mix. It greatly reduces the amount of power needed to lay the proper bead with the right penetration. And i know my little machine has a hell of a time with stainless when using straight argon.
martinsmartin
Aug 15, 2015 07:34 PM
muttleytm
Jul 14, 2015 05:31 PM
