using a cam gear on a turbo car, a waste or a nescessity???
Old Feb 13, 2006
ncirom2003's Avatar
im turboing my car with tsi kit around 10psi with PnP ex head with stg 2 turbo cam. im using the emanage and i wanna get the best possible tune...... i was told that a cam gear would be a waste of money and its not needed to tune on a turbo car.............are these people retarded or correct?
Old Feb 13, 2006
well you have an aftermarket cam, and guess what you need to tune it? yes a cam gear
Old Feb 13, 2006
ncirom2003's Avatar
wasnt the question.
let me put it this way, people were saying that adjusting valvetrain timing wouldnt make much of a difference worth bothering with the money on a turbo car. so im here asking the guys who tune turbo cars all the time or who know craploads about them if thats true or if i should get the cam gear cus it could help alot.
Old Feb 13, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
best spot for these cars seems to be at 0 degrees. spend the money elsewhere IMO. All you wind up doing is shifting the power up or down, it honestly seems to be a complete waist of time with a sohc turbo honda. Unless you are in full blown race only mode where money and dyno time is no option, spend the money on something else. my cam gear is set a 0 and next time around Ill probably put the stock one back on.
Old Feb 13, 2006
02fpcivic's Avatar
I just wanna add that if you deck the crap out of the head and/or the block its not a bad idea to degree the cam in somehow or another, and then set it to compensate for the change in deck height. You may get more HP from playing with cam timing but I think you will find that its not worth it.
Old Feb 13, 2006
ncirom2003's Avatar
thanks, see thats what i was hearing is that since its sohc not to bother, but i figured they were just maybe being ignorant, guess not.
anyone else have opinions?
Old Feb 13, 2006
when i had the cam gear tuned with pnp head, a gained 5whp on my auto without any low end loss when retarding 1.5 degrees. i'm sure its different with turbo. I always heard you're supposed to retard timing to compensate for higher compression of the turbo. isn't that what tsi recommends?
Old Feb 13, 2006
turboengnr's Avatar
DONT PANIC
people spend $1000+ on mods for an NA car that yield a total gain of about 10 whp.
You can gain more than that by tuning the car with a cam gear. And the cam gear costs what, $250? And it is easy as hell to install.
As long as you tune every aspect (cam timing, ignition timing, fuel) you will most likely see a good gain from it.
I know this is different, but we installed cam gears on my friends turbochaged B18B, and gained 40 whp on 8 psi. I dont think you will have gains that are that large, but you will see some gains if its done right.
Old Feb 13, 2006
tfnaaf's Avatar
BLDNPSI Mod
^^^^^ would be the most correct statement. If we had dual OHC's then yes i could see some possible gains but we dont!
Old Feb 13, 2006
ncirom2003's Avatar
they mean ignition timing.
Old Feb 13, 2006
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
This is the biggest use for the cam gear.
Old Feb 13, 2006
ncirom2003's Avatar
im talking about FI not NA, and trust me i know and believe in the thought that any mod is a waste unless you get the car well tuned, so id get it fully tuned right away. as for your friend did he gain that from a tune or from just cam timing? either way that info doesnt help, i mean was he making 200 b4 or 900........see what im gettin at?
Old Feb 13, 2006
02fpcivic's Avatar
Im not gunna completely say its not gunna help. Im just saying I didnt see any gains either way, maybe you will have better results. I have a custom ground cam and it works out about the same as the stock one did on the dyno. If I advance it a degree or two, it shifts the power more toward mid range (lowers power curve), if I retarded it the results were inversly similar. On a DOHC motor you can tune a bunch out of the motor, I have heard of gains of up to 15-20 whp on a fully built setup.
Old Feb 13, 2006
turboengnr's Avatar
DONT PANIC
i was only using the NA thing as a reference to the amount of money most people spend to make an additional 10 hp.
I know your FI, and the rest of the post was geared towards you.
I am going to run an adjustable cam gear later on with my setup. So i guess if you dont test it out, i will.
Old Feb 13, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Dude wth? I thought YOU were Turboengnr? highly confused..
Old Feb 13, 2006
ncirom2003's Avatar
hmmm well i think i may just get it anyways, but continue to discuss this because id be very interested in any info people can come up with.
Old Feb 13, 2006
02fpcivic's Avatar
Make sure to buy a 5 bolt gear if you can. I have heard of the 3 bolt style slipping. Mine hasnt slipped but for the same money I'd just get the 5 bolt to be sure.
Old Feb 13, 2006
ncirom2003's Avatar
yea getting 5 bolt
Old Feb 13, 2006
drunkenmagnum's Avatar
im getting one.
if nothing elese at least it will look cool.<<<< ( flame me if you must!)
you did say you could move the power band right? i wouldnt mind lowering mine a bit to make it a little more usefull.
Old Feb 13, 2006
02fpcivic's Avatar
well IDK how helpfull that will be, you will more than likely be climbing out of your peak power sooner. That may actually slow you down. You really hafta know just what you need if you are gunna start playing with cam timing.
Old Feb 13, 2006
turboengnr's Avatar
DONT PANIC
What? I am turboengnr.
Old Feb 13, 2006
XSRCivic's Avatar
^^^ "Catalyst"
I thought you (turboengnr) were him?
Old Feb 13, 2006
turboengnr's Avatar
DONT PANIC
Old Feb 13, 2006
ncirom2003's Avatar
posting under two identities to sway an opinion? sneaky lol
anyways BACK ON TOPIC FELLAS!!
Old Feb 13, 2006
turboengnr's Avatar
DONT PANIC
just thought i would confuse some people. I was just on there to get some pictures, so i said "what the hell"
Old Feb 14, 2006
Havok2k1's Avatar
Wicked Pissah Admin
I'm with him. I think it will be a waste, spend the money elsewhere...
Old Feb 15, 2006
ncirom2003's Avatar
any ideas on what i should get instead of that for the money? i budgeted for it so might as well spend the money lol.
Old Feb 15, 2006
02fpcivic's Avatar
spinner hubcaps???? haha.
Old Feb 15, 2006
turboengnr's Avatar
DONT PANIC
how about some tuning time?
Old Feb 15, 2006
ncirom2003's Avatar
yea got that money in the budget too, maybe ill save a lil more towards dezods IM if its top mount TB but id like to find something else to throw on there now cus i might not have the money whenever the IM comes out.....(going to norway,sweden,denmark for vacation near summer)
cloudguy
Apr 28, 2015 05:02 AM
Tybonater
Apr 24, 2015 07:03 PM
EC3
Apr 22, 2015 07:55 PM
Blaster30
Apr 22, 2015 12:21 PM
thesushiboy
Apr 12, 2015 07:40 PM
