2003 Honda Civic is throwing a code - P1298
Old Feb 3, 2006
reject's Avatar
reject is an unknown quantity at this point
The car is bone stock with 60xxx miles on it.
So far I found - P1298 High Voltage In ELD Circuit
Anyone know what the problem is? Its a 2003 Civic, when driving the car it feels like the car is missing every few mins. Could it be the alternator going bad?
I also found this and I hope it's not the problem - well I can't post the url to the article becuase I'm new and don't have 15+ posts, but it talks about the alternator and the ELD circuit -
If voltage on the green/red wire doesn't drop when you turn on the headlights, the ELD has failed. Fixing it requires replacing the main fuse box. A hard ELD failure should set OBI) II code P1297 or P1298.
How hard is it to replace the entire fuse box?!?
Old Feb 3, 2006
you only need to replace the eld located in the fuse box.
Old Feb 3, 2006
reject's Avatar
Cool thanks for the info.
Old May 8, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Doyou think it could be a battery isue, my 01 battery is original.
Old May 8, 2006
CraigW's Avatar
Have you had a meter on it to monitor actual voltage ?? The voltage jumps around a lot. I would say 14.3-14.5 volts would be max.
The battery would have SOMEWHAT of a regulating property, but the regulator and the ELD would do the most work.
Old May 8, 2006
azn2k1civic's Avatar
azn2k1civic is an unknown quantity at this point
could be a bad o2 sensor...my brother's corolla was doing something like what you described and found out his o2 sensor was bad.
Old May 9, 2006
Cwsl02's Avatar
Cwsl02 is an unknown quantity at this point
its a manufacture code.... the first digit is either going to be 1 or 0 if its a one its a manufacture code and if its 0 then its a genic code.... sorry to say but your going to have to bring it back to factory to get it checked out.
Old May 9, 2006
zen_master's Avatar
replacing the whole fuse box (interior) would be a very interesting job....that I higly suggest for other more experienced people to do it if ur not sure whats going on...lol
Old Jun 20, 2006
ugabuga's Avatar
ugabuga is an unknown quantity at this point
if the first number of the code is a 1 just look up the Honda specific codes which are stickied on here. no need to take it to the dealer.
Old Jun 22, 2006
I also got that code once, I needed a primary o2 also.
rcolosi
Apr 29, 2015 07:48 PM
alexkharden
Apr 23, 2015 07:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
