slow start
Drunken Master-7thgen Ninja
slow start
its happened 2 to 3 times in the past week. i get in, put down the clutch, start it and it starts a little sluggishly. like 4 clicks instead of 2 normally. i am low on gas, so that might be it, or it could be plugs, or something else. battery? help. thanx
no not clutch clicks. 4 starter clicks. normally its like 2-3 on a dead motor and like 2 on warm/hot. i filled up after work tonight and it started fine. ill check again tomorrow morning.
Mine does this too, I just upgraded to a new kenwood deck 5.0 and a 300w amp and two 10" subs and apline-s (no multi channel amp yet the deck can push those pretty well) could that be a problem, it did this with half a tank, and I know my battery was still good before this. Oh well I just need to go out and get an optima yellow-top just havent found a place that has them in stock locally.
well leaving in the on position builds some fuel pressure. it takes a bit longer to start if you just start it up by turning the key fast.
Originally Posted by gearbox
uh yea the gas isn't it. do you leave it in ON position for a few seconds before cranking? just get a new battery and plugs.
Originally Posted by MajinB
no i don't wait. and i don't need new plugs. my iridiums are fine. my battery is fine. i don't wait a few seconds. maybe i should
dragonsblood
Apr 27, 2015 12:28 PM
black2k1vtec
Dec 6, 2001 09:49 PM
