slow start
Old Feb 1, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
slow start
its happened 2 to 3 times in the past week. i get in, put down the clutch, start it and it starts a little sluggishly. like 4 clicks instead of 2 normally. i am low on gas, so that might be it, or it could be plugs, or something else. battery? help. thanx
Old Feb 1, 2006
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
Ehhh how low on gas are you......I havnt had thishappen to my current 7thgen but I have a 6th gen as well and it does that when it is low on fuel.
Old Feb 1, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
4 clicks? ... your clutch clicks?
fill up on gas ... if it still does that, then check your plugs and your oil level.
Old Feb 1, 2006
MajinB's Avatar
no not clutch clicks. 4 starter clicks. normally its like 2-3 on a dead motor and like 2 on warm/hot. i filled up after work tonight and it started fine. ill check again tomorrow morning.
Old Feb 1, 2006
Syke Fu's Avatar
Syke Fu will become famous soon enough
Mine does something similar. Only happens every know and then, except it doesn't matter how much gas i have.
Old Feb 3, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
change the battery..
Old Feb 3, 2006
MajinB's Avatar
it was the gas. didn't happen again. but my light was not on when i turned the car off. it did come on when i started it slow though.(gas light)
Old Feb 5, 2006
fieryhill's Avatar
fieryhill is an unknown quantity at this point
Mine does this too, I just upgraded to a new kenwood deck 5.0 and a 300w amp and two 10" subs and apline-s (no multi channel amp yet the deck can push those pretty well) could that be a problem, it did this with half a tank, and I know my battery was still good before this. Oh well I just need to go out and get an optima yellow-top just havent found a place that has them in stock locally.
Old Feb 5, 2006
dru106's Avatar
ThE CoRRupToR
battery.........
Old Feb 5, 2006
uh yea the gas isn't it. do you leave it in ON position for a few seconds before cranking? just get a new battery and plugs.
Old Feb 5, 2006
fieryhill's Avatar
I'm not sure if you were asking me or MajinB, prolly MajinB, but I just stick the key and go, is that really that bad?
Old Feb 5, 2006
well leaving in the on position builds some fuel pressure. it takes a bit longer to start if you just start it up by turning the key fast.
Old Feb 5, 2006
MajinB's Avatar
no i don't wait. and i don't need new plugs. my iridiums are fine. my battery is fine. i don't wait a few seconds. maybe i should
Old Feb 5, 2006
fieryhill's Avatar
I tried it [edit]what you suggested gearbox[edit]when I left work an hour ago, and it started right up, still need to go get an optima battery though.
Old Feb 5, 2006
well try leaving it in the on position a few secs before cranking. prolly will fix it.
usajags84
May 10, 2015 08:11 AM
dragonsblood
Apr 27, 2015 12:28 PM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
