Is Honda ATF, synthetic?
EDIT: I SEARCHED FOR HOW MANY QUARTS TO ADD WHEN CHANGING... SOMEONE SAID ADD 3 THEN CHECK THE LEVEL... I ADDED 3 AND IT WAS WAY OVER THE LINE.
so does anyone know how many quarts of atf to add when changing? is it just 2? or 2 1/2? 3 is definitely to much
Since you're using the ATF-Z1... you must use 2.5 Litres. I myself put 2.6 Litres. Just drain it like oil, then get a funnel and stick where the dipstick goes and drop in 2.5 - 2.6 LITERS.
I don't have the bottle infront of me, but to save you the confusion, put 2.5 - 2.6 bottles.
As for being synthetic, I'm not sure... but it doesn't matter, you should only use the Honda ATF-Z1 anyway.
thanks, i dont know, i flushed it, put in 3 and it was way over, flush it again, put in 2 and it was way under... then i put in 2.5 and it was right on the line... hope i didnt mess anything up driving it with only 2 in there for a lil bit.
BootyDo
May 7, 2015 04:46 PM
markp94
Apr 30, 2015 09:19 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
