Is Honda ATF, synthetic? - Honda Civic Forum
Old 01-27-2006
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
EDIT: I SEARCHED FOR HOW MANY QUARTS TO ADD WHEN CHANGING... SOMEONE SAID ADD 3 THEN CHECK THE LEVEL... I ADDED 3 AND IT WAS WAY OVER THE LINE.
so does anyone know how many quarts of atf to add when changing? is it just 2? or 2 1/2? 3 is definitely to much
teg91ls is offline
Old 01-27-2006
DOHC i-VTEC TiMEX
aznboysrfr's Avatar
I've heard bad things about using non-honda atf in the d17 auto trannies.
and no, I don't think it's synthetic
aznboysrfr is offline
Old 01-27-2006
L23Tan is an unknown quantity at this point
Since you're using the ATF-Z1... you must use 2.5 Litres. I myself put 2.6 Litres. Just drain it like oil, then get a funnel and stick where the dipstick goes and drop in 2.5 - 2.6 LITERS.
I don't have the bottle infront of me, but to save you the confusion, put 2.5 - 2.6 bottles.
As for being synthetic, I'm not sure... but it doesn't matter, you should only use the Honda ATF-Z1 anyway.
L23Tan is offline
Old 01-27-2006
how many quarts? however much it takes to fill the level to max when the engine is running and warmed up.
gearbox is offline
Old 01-27-2006
thanks, i dont know, i flushed it, put in 3 and it was way over, flush it again, put in 2 and it was way under... then i put in 2.5 and it was right on the line... hope i didnt mess anything up driving it with only 2 in there for a lil bit.
teg91ls is offline
Old 01-27-2006
either way i think i finally got my tranny running good, just have to let it warm up becuz it shifts like crap when its cold, otherwise, i think im good to go.
teg91ls is offline
Old 01-27-2006
leave in d3 to warm it faster
gearbox is offline
Old 01-27-2006
streetglower's Avatar
the auto tranny takes 2.9 quarts on a drain and fill. I just add all 3 quarts in and it is a small amount above the line which is no cause for concern.
streetglower is offline
BootyDo
05-07-2015 05:46 PM
markp94
04-30-2015 10:19 PM
Herman49
6th Generation Civic
04-29-2015 02:22 PM
jessicakaybby
04-20-2015 01:11 PM
Bartkat
20
02-19-2002 02:29 PM
Quick Reply: Is Honda ATF, synthetic?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
