HX fuel economy
Old Jan 23, 2006
hxmiser's Avatar
hxmiser is an unknown quantity at this point
HX fuel economy
Any ideas as to why gas mileage on my 2003 HX ain't what it used to be? I have 72,000 miles on it and gas mileage (which I measure at every fill-up!) has been slipping, probably by about 5-10%. All important maintenance has been done (air filter, plugs, oil changes, tire pressure monitored). Is it possible that it could be running a little too rich? if so, can the mixture be adjusted by a backyard mechanic with limited resources such as myself?
Any suggestions are appreciated...
Old Jan 23, 2006
zadscmc's Avatar
zadscmc has a spectacular aura aboutzadscmc has a spectacular aura aboutzadscmc has a spectacular aura about
Are you in a cold weather area? If so, a 5-10 percent drop since summer would be about correct. If not, make sure that you are not carrying any extra weight. Check the pressure again, cold, sometimes one tire being off can cause a 2-3 percent reduction. Check for obstacles blocking the air intake, something might have gotten sucked up into the intake. Lastly, make sure the parking brake is completely disengaged (I had a car once that the light wouldn't go on until the SECOND click).
Those are about all the tips I can give you.
Old Jan 25, 2006
hxmiser's Avatar
ok thanks for the input Zac.
Yes, I'm in frozen NY, so that could be it. I was also thinking of buying one of those Tornadoair things for the intake to swirl my mixture, which makes total sense to me. For now I guess I will have to live with 40mpg...
Old Jan 25, 2006
streetglower's Avatar
your complaining about 40MPG????
Most of us here arent getting even 30 MPG and we are satisfied. I get about 31 MPG all highway miles. And that to me is fine. That also is with 111K miles on an 02.
If you are getting 40 MPG then nothing is wrong with your vehicle.
Old Jan 25, 2006
Ricky's Avatar
Ricky is an unknown quantity at this point
try get your Valves clearance adjusted that may be causing it too..
Old Jan 25, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
do u warm up ur car?
Old Jan 25, 2006
Jrfish007's Avatar
My aunt get 50 MPG out of her HX.... but drives slower than my grandmother.
Anyway, cold weather hurts MPG. My truck went from 19 MPG during the summer to 15 MPG here in Ohio.
Old Jan 25, 2006
Jrfish007's Avatar
Do not buy a Tornado thing..... many people have proven that does not work, in fact some people have had the fins break and get sucked down the intake and into the engine. It doesn't work because the engine now has to pull harder to get air in to make it swirl. So while you gain .2 MPG because of the swirl effect, you loose .5 MPG because it is hard to pull it in.
Old Jan 26, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
um dude dont be bitching about 40mph. i get like 20-25....no joke...checked last time
Old Jan 26, 2006
zadscmc's Avatar
This is a dual edged sword. The car certainly runs better when warmed up, however, during that time period that the car is not moving, you are getting 0 mpg.
As a hybrid owner, our philosophy is to warm the car up while driving. Drive the car at modest RPM and speed until the engine is at running temperature. Better to be moving while warming rather than sitting.
Old Jan 26, 2006
www.lubecontrol.com
Old Jan 26, 2006
zadscmc's Avatar
Originally Posted by gearbox
lubecontrol
I use this and love it.
Old Jan 26, 2006
schematicsskate's Avatar
schematicsskate will become famous soon enoughschematicsskate will become famous soon enough
I just checked mine, i drive a HX. 29.6mpg. Now here in wisconsin its been like 20 degrees outside and there a couple redlines on that tank. Normally its better.
Donahue
Sep 8, 2015 09:00 AM
Bman2212
Sep 2, 2015 11:49 AM
Civicircus
Aug 6, 2015 11:58 PM
alxz310
Jul 30, 2015 12:18 PM
