Greasing Clutch
Old Jan 10, 2006
Pharoh's Avatar
Bobaganoosh!
Greasing Clutch
My clutch has started to creak really bad to the point where it's all I can hear when I drive..my civic is a 2k1 and it's on it's original clutch.
Is this just a matter of greasing it or should I be looking deeper?
Old Jan 10, 2006
streetglower's Avatar
is it making the noise at the clutch pedal or does it sound like its coming from internally?
Old Jan 10, 2006
Ser1N's Avatar
EK Hatch
Ser1N is an unknown quantity at this point
My 7th gen has the same problem so does my 6th =/
Old Jan 10, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Try greasing 2 things.... the return spring in the car (especially if you hear it real loud) and the ball joint on the fork, which is under the hood, if you look up by the front passenger side corner of the motor where the transmission meets the engine, there's a 1" x 4" or so rubber boot, its got a slit in it, trace the clutch line to it, in there is the fork, there's a steel ball joint in there that seems to get went and corrode, when it does, it squeaks. I've found the ultimate solution to that is go to honda and get some Odyssey sliding door grease (I don't know what its called, but its the Honda grease for the mini-van door) and slobber it all over the joint in there.
Old Jan 16, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
my prob isnt as bad as his but ummmm when im going into third i grind a bit....and i have the clutch allll the way down to the floor but it happens at such random times....why? O_O
Old Jan 16, 2006
Ser1N's Avatar
EK Hatch
I think that would be your tranny, How many miles do you have?
Old Jan 16, 2006
just hit 40k made me sad but yeah 40 k but it also randomly did it at 35k
Old Jan 16, 2006
Ser1N's Avatar
EK Hatch
hM, well i dont think that would be the clutch, what will help for the tranny, is http://www.pennzoil.com/products/gea...cro_fluid.html
Synchromesh, this stuff works great for grinds.
Old Jan 22, 2006
supertuner's Avatar
supertuner is an unknown quantity at this point
does it sqeak when you push in the pedal or when the clutch is engaged ?
Old Jan 22, 2006
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
i named my car sqeaker cuz of the pedal. it is funny i can make him talk.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
