Boost Gauge problem HELP
Old Jan 9, 2006
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Exclamation Boost Gauge problem HELP
I have the Greddy profect E-01 and the boost is reading at 8psi which is what I have it set to at the moment but mu boost gauge and my TSI injection control unit is reading 11psi? I have no idea what is going on. The greddy pressure sensor and the boostgauge are all connected to the same line. Any Ideas. I know that the pressure sensor came with its own t-fitting with some little brass nipple thing in the end of the t-fitting. Could that be the problem. The car feels like it is running at 8psi but why are the others reading at 11psi? Please help.
Old Jan 9, 2006
turboengnr's Avatar
DONT PANIC
some pressure senders and guages arent very accurate.
Which brand guage is it? Is it mechanical or electric? And what brand MAP sensor does the TSI unit use?
I would probably listen to the majority of the guages.
Old Jan 9, 2006
Jeff's Avatar
Jeff is an unknown quantity at this point
I use the same boost controller with a autometer colbat boost gauge and mine runs the same on both. My friends integra with the same boost controller with a cheap boost gauge is off all the time by like 2 psi.
Old Jan 9, 2006
tfnaaf's Avatar
BLDNPSI Mod
ive read that most all boost guages are low by 2psi approx, not sure if this is myth or not
Old Jan 10, 2006
zach_04LX's Avatar
zach_04LX is an unknown quantity at this point
My experience is that the TSI gauge is not very reliable. I would trust your Greddy one instead.
Old Jan 10, 2006
turboengnr's Avatar
DONT PANIC
But its not just 1 guage versus another. It is 2 vs. 1
When 2 read higher than the other, i would back the boost down just to be safe.
Think of it this way.... You have 4 egt guages in your airplane (atleast i do). You are flying at 6,000 ft, and all of a sudden 3 of your 4 guages start to show that you are running at 1400* instead of 800*.
What do you do?
Even though one of them still says you are safe, you back the throttle off until it is within reasonable parameters.
I would turn the boost down until you have something proving what your true boost level is.
Old Jan 10, 2006
CrewChief's Avatar
I have the electric Autometer C2 gauges. I have to double check. I think the only one that is reading off now is the TSI gauge. If so I'll just use a clamp to restrict the air going to the TSI pressure sensor till it reads the same. Thanks a bunch guys. I was pulling my hair out for a min.
Old Jan 10, 2006
eye_see_you's Avatar
let the devil out
well my TSI controller read what was displayed on my gauge so something is strange. I never seen a tsi boost gauge unless you are speaking of the controller unit that connects to the MAP box etc.
Old Jan 10, 2006
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
I don't want to kill this thread but I also have the Eo-1 boost controller. I have power running to it but I stll didn't connect the solenoid valve and the pressure sensor. For the pressure sensor did you guys tap into the boost gauge vaccum line or to something else. If I were you I would trust the Eo-1 boost reading over the other two readings. I know my Defi gauge reads exactly the psi as my Tial wastegate spring which is 5.8 PSI, it just stays right underneath the 6 when I punch it. Good luck with everything.
Old Jan 10, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Chief is talking about TSI controller box boost gauge.
Mechanical gages are not as accurate as electrinic gauges.
But problem with tsi electo gauge is - it doesnt have decimal, it can only read a straight number, 1,2,3...8,9....
So the actual 8psi can be either 7.7 or 8.4 or 8.5, so this is where difference come from.
So, crewchief's 11psi, could well be 10.5 rounded up to 11, and I'm not sure with profec, but if it doesnt have decimals on readout it may also show rounded up figures...
Old Jan 10, 2006
CrewChief's Avatar
Ok guys thatnks for all your help. I messed around with the Profect today and took it all the way down to 6psi which is the wastegate spring rate and all 3 gauges read 6psi. hmmm now i'm confused. So i will mess around with it some more. Not really sure what is going on so ya. I'll keep everyone informed.
Old Jan 10, 2006
dezod's Avatar
7thgen Power Maker
How's the setup running? Any pics?
Old Jan 10, 2006
Michalo187's Avatar
Abortion Survivor
My e-01 is the other way around it reads crazy amounts when my autometer reads like 8. They will both read 8 at times and then i let off the gas and the e-01 goes all the way up to like 13 or something. Supposebly though the e-01 is more accurate. it also says my max boost is 13.6 and it didn't feel like i have ever ran that much
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
werdnahall
May 17, 2015 11:37 AM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
