Just Got A 2" Drop
Old Jan 3, 2006
SIXTY's Avatar
SIXTY is an unknown quantity at this point
Just Got A 2" Drop
I just got a Arospeed 2.0" drop and i was wondering how much lower its going to get after it "settles" i can fit 2fingers in the front and 3 in the bacc
Old Jan 3, 2006
RHCP0801's Avatar
<------------ jealous-----put some pics up first
Old Jan 3, 2006
Rennen's Avatar
New Mod on the Block
you must have really small fingers. well... i have neuspeed sports with a 1.75 in the front and 1.5 in the back. i have about a 1 finger gap all around. so im guessing that your gonna have no gap.
Old Jan 3, 2006
klectic's Avatar
klectic has a spectacular aura aboutklectic has a spectacular aura aboutklectic has a spectacular aura about
i got the same problem as you too dood
on progress sports
been wanting to shed some light on this topic for a while now...
ppl say it takes a few days to settle, others say a few weeks, some said months or so..
best advice i learned
drive it around a lot
Old Jan 3, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
Originally Posted by varner88
uhm if it was cheap springs ur stick with that i got cheap one that sed 2.5 inch drop and the spring waslike 2 inches bigger then the oem spring
well you're not sposed to judge the spring when its off the setup, if thats what you did.
Old Jan 3, 2006
slammedSI's Avatar
slammedSI is an unknown quantity at this point
lol and ur saying if the spring is bigger then oem it will give you a drop...? PLease
it depends on the spring rate. how stiff the spring is, for lack of better words. the springs can be bigger but softer and still give you a drop.
Old Jan 3, 2006
Christian Calim's Avatar
Christian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to behold
ha! i had those springs before arospeeds. they were really shitty on my sedan. sagged like crazy int the rear leaving no finger gaps at all they were officially made for coupes so you should be pretty good.
Old Jan 3, 2006
synod's Avatar
synod is an unknown quantity at this point
Yea, aftermarket springs can be longer than your stock when not installed and still give you a drop. They just "give" more I guess is a good way to say it.
spring physics
Look over the "k" variables, it's called the spring coefficient and measures spring stiffness. That page is actually for spring oscillation, but you get the idea.
Old Jan 3, 2006
shroomster's Avatar
no......I wasn't arguing your point, sorry if it reads that way. I was just saying what I actually read on a box that has my g/f new springs in it about don't judge the height of the new spring to what the o.e.m spring looks like when fully expanded off the vehicle. like someone else said it is also not a good thing to do it that way as you can't tell by the height what the rate is either it could be taller to be softer to give more flex. but will compress more as the spring rate is lower. i think thats how it works....
Old Jan 4, 2006
jttegx's Avatar
OMNES AD UNUM
your drop shouldnt be calculated by how much finger gap you have left but how much distance was eliminated from the hub to body.
Old Jan 4, 2006
SIXTY's Avatar
ya but i was just wondering how much they settle, like a inch more or .... just wonderin
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Juanb24
Sep 15, 2015 12:39 AM
