Do auto tranny treatments work?
Old Dec 22, 2005
taehoshi's Avatar
taehoshi is an unknown quantity at this point
Do they work? if so, which brand do u recommend?
Thanks
Old Dec 22, 2005
Jrfish007's Avatar
Just change the tranny fluid like the manual says. Don't go to a quick lube place either, go to honda. Those quick lube places use a pressurized system that doesn't seem to work to well with these trannies. Use only Honda ATF, I've heard Redline is good to. Don't use some Autozone crap, the Honda ATF is not the same and it will screw everyhting up.
Old Dec 22, 2005
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
ive used lucas tranny additive and my auto tranny seems to shift better and smoother. I noticed some slippage before i added it and now its alot better just my 25 cents
Old Dec 22, 2005
taehoshi's Avatar
cool
i may try that.
i was told from my mechanic to put in some tranny fluid cuz apparently it's making more noise than it should
are you supposed to put the treatment via the dipstick? ...just making sure
Old Dec 22, 2005
make sure its full when the enigine is warmed up. use honda atf only. additives will not fix any problems, only give you a little time before it breaks down.
Old Dec 27, 2005
Matulin407's Avatar
true that^^, and yes u do add it via dip stick, gotta buy a tranny funnel comes witha lil hose attachment fits right in there. And when u add that lucas stuff u need like a paint stick something to swirl it around is it goes down the funnel. its realllly thick. also before u do that u might wanna change ur tranny fluid if u havent recently. Im bringin mine in tommorow.
honda dude says u should do it every 10-15k or so. cuz are trannys suck at dissapating heat and heat damage occurs quick. My flywheel is heat damaged already.!!!
Ninetyatecivic
May 9, 2015 07:48 PM
Jigee
May 9, 2015 11:18 AM
ORskier
May 3, 2015 12:54 PM
bsmiley
Apr 27, 2015 01:27 PM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
