Do auto tranny treatments work? - Honda Civic Forum
Old 12-22-2005
taehoshi's Avatar
taehoshi is an unknown quantity at this point
Do they work? if so, which brand do u recommend?
Thanks
taehoshi is offline
Old 12-22-2005
Jrfish007's Avatar
Just change the tranny fluid like the manual says. Don't go to a quick lube place either, go to honda. Those quick lube places use a pressurized system that doesn't seem to work to well with these trannies. Use only Honda ATF, I've heard Redline is good to. Don't use some Autozone crap, the Honda ATF is not the same and it will screw everyhting up.
Jrfish007 is offline
Old 12-22-2005
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
ive used lucas tranny additive and my auto tranny seems to shift better and smoother. I noticed some slippage before i added it and now its alot better just my 25 cents
Matulin407 is offline
Old 12-23-2005
taehoshi's Avatar
cool
i may try that.
i was told from my mechanic to put in some tranny fluid cuz apparently it's making more noise than it should
are you supposed to put the treatment via the dipstick? ...just making sure
taehoshi is offline
Old 12-23-2005
make sure its full when the enigine is warmed up. use honda atf only. additives will not fix any problems, only give you a little time before it breaks down.
gearbox is offline
Old 12-27-2005
Matulin407's Avatar
true that^^, and yes u do add it via dip stick, gotta buy a tranny funnel comes witha lil hose attachment fits right in there. And when u add that lucas stuff u need like a paint stick something to swirl it around is it goes down the funnel. its realllly thick. also before u do that u might wanna change ur tranny fluid if u havent recently. Im bringin mine in tommorow.
honda dude says u should do it every 10-15k or so. cuz are trannys suck at dissapating heat and heat damage occurs quick. My flywheel is heat damaged already.!!!
Ninetyatecivic
05-09-2015 08:48 PM
Jigee
6th Generation Civic
05-09-2015 12:18 PM
ORskier
05-03-2015 01:54 PM
bsmiley
7th Generation Civic
04-27-2015 02:27 PM
CiViCPrAnInG2k1
12-06-2001 01:14 PM
Quick Reply: Do auto tranny treatments work?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
