Some weird noise, I can't figure out!
Old Nov 25, 2005
civicowners's Avatar
civicowners is an unknown quantity at this point
When I start my car and press on gas just a little bit, I hear some weird noise coming out from under the hood, probably the engine bay. The noise sound like boiling liquid. Even when I drive for the first 10 minutes, I hear the boiling noise after 10 minutes or so, the noice is gone.
What could it be?
Old Nov 26, 2005
Smilla's Avatar
Smilla is an unknown quantity at this point
Hey I have a similar problem. When I give it a little gas and I'm going slow like 5-10 mph, it makes a deep buzzing sound from under the hood. I think I might have read about a TSB saying the catalytic converter cover might be loose or something like that. It only seems to happen sometimes.
Old Nov 26, 2005
well the car runs rich when first started so its prolly gas in the exhaust. if it doesn't do it once the car is warm, i wouldn't worry.
Old Nov 27, 2005
I still hear that noise sometimes even when the car is warmed up.
Old Nov 27, 2005
does it sound like rushing water, like a river flowing through the dash? if so it could be air bubbles in the heater core. I have it too but i'm leaking coolant. try turning the temp to hot (it should do it) and then cold (should not do it).
Old Nov 28, 2005
yea it does sound like rushing water but not in the dash. It's lower, near the transmission but under the hood, somewhere in the middle.
Old Nov 28, 2005
mackin's Avatar
mackin is an unknown quantity at this point
i have the same problem too..it only happens at low speeds like at the start of first gear....any fixes??
Old Nov 28, 2005
well assuming you don't have a problem like blown gasket, you can bleed the air out. When car is cold, remove radiator cap. Start car, warm up to operating temp by revving the motor. Watch the radiator for coolant if it spills out let the rpm drop. Once car is at temp, turn heater to full blast and watch as any air bubbles pop at the surface. You can add coolant to fill the radiator near the top if you can't see coolant. Turn off car, replace cap.
Old Dec 15, 2005
mackin's Avatar
would the dealer fix this under warranty? what would the cause of this?? filling up the engine oil too much/ too low during oil change?
Old Dec 15, 2005
the water sound? i don't know. i just had the headgasket replaced and bled the air out but i still get the water sounds. its coolant flowing through the heater core, but i didn't think it made that sound before. maybe its normal?
Old Dec 17, 2005
taehoshi's Avatar
taehoshi is an unknown quantity at this point
I also have a problem with interior noise from under the hood.
Im pretty sure it has something to do with the exhaust system, i just dont know which part. Whenever my auto tranny is about to change gears you can hear a lot of noise than usual as if the engine is struggling a bit before going into the next gear. Whenever i rev a bit hard the sound is very noticeable. I dont have a heat shield in my car; could that be the problem? I tried revving the engine in park and it sounds perfectly fine.
Anyone ever have any problems like this?
Reverb2005
Jun 26, 2015 06:22 PM
rayman7
Jun 20, 2015 09:48 PM
MamaBear2015
Jun 11, 2015 07:33 PM
rcolosi
Apr 29, 2015 07:48 PM
SSMatey
Apr 13, 2015 06:09 PM
