Who's got a turbo that has to pass emissions?
Old Nov 22, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Question 1, does it pass (and with flying colors)?
2 is how do they do the inspection?
Around here its the OBD scan, but I don't know if it just shows error codes or numeric values of stuff. I know people have gotten swapped cars through around here, and there's more than a few modified cars running around, so its doable, I'm just curious how.
The other thing is... how hard did you have to tune it to get it to pass if it failed the first time... basically, will a well tuned car pass with just as easy flying colors as a plain old one (assuming all stock emissions hardware is kept)?
Old Nov 22, 2005
puidokas's Avatar
puidokas is an unknown quantity at this point
where im from im almost positive if the CEL isnt on ill pass.
Old Nov 23, 2005
iamboo's Avatar
Retired - SoCal FI Mod
if you live in california...
forget about passing if you have a turbo kit... you will fail visual inspection for sure and unless you have a good catalytic converter, you're not going to pass the tailpipe emissions test either...
you can always pay a smog guy off, but that's illegal and the shop owner can be fined 50,000 dollars and get his smog testing license taken away...
Old Nov 23, 2005
civic01vtec's Avatar
In my area, it is visual only and a gas cap leak test.
Old Nov 23, 2005
Jap-Euro Fusion
Originally Posted by Sujak
If you turbo your civic are you gaurenteed to fail your emissions without tweaking it right before you go? Or is it just random that you failed it? I know turbo's involve alot of maintance.
I don't have one. Its a hypothetical question because I'm curious how its done.
Old Nov 23, 2005
tfnaaf's Avatar
BLDNPSI Mod
here in boise they only do an OBD2 scan and thats it, it looks for 8 things and you can only fail 3 of the eight. I havent had mine tested yet, but it should pass easily. Worse case senario , swap the old cat/manifold on and retest. later tonight if i remember ill see if i can find the list that they look for with the scan
Old Nov 23, 2005
djmota's Avatar
Originally Posted by varner88
where i live the guys are idiots they failed me 3 times cuz they didnt see my cat converter under the car lol on a lx....... they didnt realize it was built into the header hes like i dont see any wires coming from your resinator!! hah!!!
too funny
Old Nov 25, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
move to TX, and you can run open header. LOL but it's true, emissions restriction are lax overhere.
Old Nov 25, 2005
zach_04LX's Avatar
zach_04LX is an unknown quantity at this point
Here it is basically if you have a cat or not. Therefore, make sure to buy a cheap-*** cat that you can replace the test-pipe with and you should be fine (at least in STL).
Old Nov 26, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
I think the only way to pass is to have friends who do inspections. That way they can "overlook" the visual part and just do the OBDII scanning. Don't throw and codes and you will pass.
Old Nov 27, 2005
mrDFWmechanic's Avatar
where i go they just plug the obdII tester in and thats it
Old Nov 27, 2005
SLO REX's Avatar
250+ awhp Stage 2
Well if you come to where I live, Tawakoni, they just start the car and drive it 10 feet and then make sure the horn works and they give you the sticker. Got to love small towns where no one gives a ****.
Old Nov 27, 2005
ajhdragon's Avatar
7thgens official a$$hole
its not if you have a cat or not that is for inspection. here its a scanner. just tweak your settigns before you go in and then after change them back.
Old Nov 27, 2005
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
Here In Puerto Rico I know a friend that can make my car's inspection for free without even inspecting it, his father runs the shop that makes the inspections :P
Old Nov 27, 2005
01civicdriver's Avatar
01civicdriver is an unknown quantity at this point
here in nebraska you dont even have to do an inspection. they dropped that a long time ago
Old Nov 27, 2005
ragingSPAM's Avatar
I just burnt my tongue
here in cali if your car is less than 6 years old than you dont need a smog test until that is up...than u need a smog test and its easy to find places that do illegal smog checks
Old Nov 27, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
certain counties in NC require emmissions test, but if you live in a rural area they do a safety inspection. in my county (wake) i found out that if i did a swap on my car to a k20 it wont pass inspection, said that they have to have the engine that the car comes with. that sucks hardcore.
Old Nov 27, 2005
SLO REX's Avatar
250+ awhp Stage 2
I got my cars inspection passed with the engine light on, and without a cat, gotta love small towns.
Old Nov 28, 2005
C2i0v0i1C's Avatar
SuperMODrizd
round here they do a tailpipe, and gas tank lid leak test.
i just got a new cat put on and im having it tuned real well so i should pass
Old Dec 3, 2005
Jap-Euro Fusion
what if you dont run a cat or say a fake cat.. if i have a 02 sim will it still show the codes? even if the light isnt on becuase they dont look under my hood they only look for a cat with wires hangin out and they stick a wire into my tailpipe..
The tail pipe sniffer will pick up the fact there isn't a cat. Think about that. O2 sims only fool the computer so the car runs.
solarpunk70
Apr 12, 2016 11:43 AM
HondaGuy7
Feb 22, 2016 01:00 PM
senicalj4579
Oct 2, 2015 10:03 AM
brags
Oct 2, 2015 05:53 AM
brash99
Sep 29, 2015 08:42 AM
