Is Time For My Tune-up
Old Nov 18, 2005
IrockCivics's Avatar
I'm going to do my tune-up on my car and I would like to know what are some good spark plugs and other stuff I need? Thanks.
Old Nov 18, 2005
Jrfish007's Avatar
Spark plugs, generally people just stick to the OEM platinum ones, their around $15 a piece in AutoZone, some people say around 3 a piece, but I think those are just platinum tip and copper core, make sure to get the pure platinum. The Iriduim work too, but I never notice a difference when I put them in versus the platinum. The direct ignition system pretty much requires the best plugs out there.
Other than plugs there is not much, no cap, rotor, wires or anything like that. So you spend more on plugs, but save on the rest, I think it costs about the same in the end.
Old Nov 18, 2005
so the ones from autozone are the same from the honda dealer but just cheaper?
Old Nov 19, 2005
Jrfish007's Avatar
Well, no, the ones you find at AutoZone are the just caps. I think Autozone has a Denso Iridium that is works well, but it's about $13. Most of their platinums I've seen (I just checked their website) are the capped ones that have a to large of a resistacne for the direct ignition systems.
Here is part number and manufacturer of the spark plugs depending on which model you have. I would search around for those exact plugs (all of them are platinum) form a different source than the delaer. I think a couple of people actually sell them on this site, check out our vendors, try Dezod or TrueHonda, I think they have them. Or where ever you can find them on the internet. I personally know a little NAPA shop by me that carries NGK and denso and I buy them there for about $10 a piece.
LX/DX/VP/HX = PZFR6F-11 (NGK) $13.something
EX = PKJ20CR-M11 (denso) $13.61
http://www.slhondaparts.com/browse.asp
In generall if it's less than $10, it's probably a cap style. I personally don't use the caped ones, but I know people on here who have used them and been fine with them. The way I see it is that the full platinum plug is what Honda put in, I would think if they could save $7-$8 for each plug, they would. SO there has to be a reason they put the expensive ones in. So I'll follow them. But to each our own
Old Nov 22, 2005
igetmadchocha's Avatar
igetmadchocha is an unknown quantity at this point
big pun rules
Old Nov 22, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
Originally Posted by igetmadchocha
big pun rules
wow hahah yeah he does. but you dragged a thread from the dead to declare your love for a dead rapper.
Old Nov 22, 2005
just get ngk vpower and change them more often. what mileage are you at? there are tons of maintenance things to do.
Old Nov 23, 2005
ok I understand now JrFISH007 thanks for breaking it down for me........... igetmadchocha I like your user name lol I love chocha and about bigpun he's my favorite I got alot of **** about him...... gearbox my mileage rite now is on 41,xxx and I bought the car with 4,xxx all I did was oil canges, brakes, new tires the easy stuff thats all I never did nothing else since I got it.
Old Nov 23, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
But's thats me, i'm at 50,000m and i've got oil, tranny, plugs, cabin filters, e-brake adj, rear drum adj, brake fluid, engine valves adjusted.
Old Nov 23, 2005
brake fluid every 3 years, tranny fluid (manual) can wait til 60k prolly but auto you're already too late, coolant every few years, get some lubecontrol.com products to clean the engine/fuel system, spark plugs? check ground connections, adjust e-brake.
Old Nov 23, 2005
Ya, I like to do my manual tranny ofted, it's a cheap price to pay for how smooth it feels after.
Old Nov 23, 2005
is it the same for a automatic?
Old Nov 23, 2005
i change auto tranny fluid every 10k. you are just doing a drain and refill, so there is always some old fluid left over. The manual says 30k, but our trannies are very fragile. I wouldn't go more than 15k, and I would definately recommend getting an oil cooler.
Old Nov 24, 2005
Jrfish007's Avatar
well, the oil cooler thing can be bad if you live in a cold area, like it's 9F outside right now. Unless you have some sort of thermostat in in the tranny fluid cooler, runnning cold fluid to your tranny could be bad. Now if you live in say Vegas or someplace hot and warm all year, then maybe a tranny cooler is a good idea. But really in cold places it is a bad idea because to cold tranny fluid can end up hurting.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
supercivic01
South
Nov 30, 2001 11:27 AM
CapYoda
Nov 11, 2001 05:17 PM
