In-tank fuel pump (main post updated!)
Old Nov 18, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Without converting to return fuel system, is there fuel pump that can deliver more fuel to injectors???
Initial post:
I want more productive fuel system for my turbo.
Does anobody know who makes replacement intank fuel pump for us?
I have a ex sedan
Old Nov 18, 2005
b00stinem2's Avatar
b00stinem2 is an unknown quantity at this point
walbro fuel pump 255
Old Nov 18, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Just do an external. you'ed be better off.
Old Nov 18, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Yes that one will work but it will not fit the same as stock. The walboro is bigger around then the stock pump.. you need to shave the pump cage for it to fit. Its not much modification to make it work.
Old Nov 18, 2005
fastest_ex's Avatar
fastest_ex is an unknown quantity at this point
i'm confused, i though we need a return fuel line to do a walbro 255...since our fuel pump is returnless, they don't make any fuel pump for our civic...i'm not a newbie...but i thought the only way to use a walbro 255 only if we do a return fuel line
Old Nov 18, 2005
b00stinem2's Avatar
i was searching on here and found this vendor and found this. if you dont have a return system here u go.
http://streetlevelperformance.com/Ho...ion%20Kit.html
Old Nov 18, 2005
XSRCivic's Avatar
You DONT need a return setup to use an aftermarket fuel pump. You DO need a return line to use an adjustable fuel pressure regulator.
Old Nov 19, 2005
Is there any honda/acura intank pump that will fit d17???
Old Nov 19, 2005
Michalo187's Avatar
Abortion Survivor
i don't think anyone has tried it yet but be my guess to be the first. I have a walbro 255
Old Nov 19, 2005
As per your profile you dont have return line conversion.
How did you install walbro pump?
Old Nov 19, 2005
fastest_ex's Avatar
i don't know if there's a differnces but for my k20 swap i used an rsx type-s fuel pump......
Old Nov 19, 2005
XSRCivic's Avatar
You don't listen..
Old Nov 19, 2005
You don't listen..
Common,
There was no specifics and you know it!
Then following Q arises:
What need to be done to use rsx-s intank pump and will it help to get more fuel to the engine?
Old Nov 19, 2005
XSRCivic's Avatar
Ok let me explain something to you. A fuel pump sends fuel, THATS IT. It is up to the ecu,regulator,injectors to determine how much. IF you use stock injectors/regulator with an aftermarket pump you have accomplished nothing. You need to either upgrade the pump and injectors and use an emanage to tune them or go all out: upgrade the pump and injectors, convert to a return setup and add an adjustable fuel pressure regulator. these 2 ways are the only PROPER way to do it. Before you ask, NO there is no adjustable fuel pressure regulator out right now that works on a returnless setup. Also there seems to be no replacement aftermarket fuel pump for our cars. Anything you do will take some modifications of the fuel pump assembly.
My suggestion to you.. get RSX Type-S injectors, Walboro 255 lph pump and emanage. Thats minimal for a turbo setup. It will give you the fuel needed to run your setup. Do it right the first time.
Old Nov 19, 2005
What you trying to explain I've already learned .... years ago.
I have a turbo set up, its running....
My problem: I need lillte extra fuel to get to the engine (to the firewall) so all my injectors can burn it.
Therefore I asked if there is something that I can use with returnless system to aid stock pump under boost to supply extra to all my 6 injectors to burn it.
My initial thought was to use rsx-s intank pump, but I dont know much about it. So if I use rsx-s pump (any other pump??) will I get more fuel to my injectors to burn or not???
Old Nov 20, 2005
HyaBoosta's Avatar
synapse engineering is working on a fuel pressure regulator that will be designed for returnless setups soon
Old Nov 20, 2005
Insider's info??
Old Nov 20, 2005
HyaBoosta's Avatar
Insider's info??
nah read about it in the new modified mag.
Old Nov 20, 2005
Main post updated!
Jonnie.
Jan 13, 2019 11:21 AM
jetcare101
May 8, 2015 01:33 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
BREADFAN
Apr 15, 2015 08:58 AM
