car surges
This car is 88 civic. Fuel Inj. The motor runs great as long as I keep the fuel tank full. It will start to lope or surge & lose power when I reach @ 3/4 tank, I'm not kidding. I've tried fuel inj. cleaners, octain boosters, high test gas & fuel filters. once I fill up - it runs great. I wonder about the fuel pump, but would the level of fuel in the tank affect this?
Sounds like a fuel pump...
It sounds like you changed the fuel filter right?
My next guess would be the fuel pump because it probably is not covered when the tank hits 3/4 full, so it's probably a seal in the fuel pump. And the classic surge and die is that of a fuel pump about to die.
Oh.... one quick test....
Next time it surges, pull over, leave the engine running and pull the gascap. If you hear a strong suction sound, you have a plugged vapor return putting too much vaccum into the tank. This will give your fuel pump a lot of trouble.
If nothing happens.... then change the pump.
usajags84
15
Aug 19, 2015 03:12 AM
F1wanabe
Apr 27, 2015 11:06 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
