Need the manual pages for brake caliper servicing....
Old Nov 14, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Can someone scan me the page or pages to rebuild the calipers? I think I know what I'm doing, but I'm sure there's a step I'll miss. Directions are good. No sense buying a new caliper when the rebuild kit is only $20.
Thanks.
Old Nov 14, 2005
mrDFWmechanic's Avatar
i have both the chiltons and hayne's manuals for our cars and neither tell how to rebuild the caliper. i posted in your thread on ht about the stuck caliper and i guess nobody helped you there. any idea where i could find those pages ??
Old Nov 14, 2005
Jap-Euro Fusion
They're being a bunch of asshats who don't seem to understand a simple diagnostic question and would rather just define for me what a stuck caliper is, which I already know what it is, or I wouldn't be looking to diagnose it as a stuck caliper. With as much as honda wants for Civic calipers, I may just go for the ITR kit instead. its not much more if I can't rebuild these.
I'm sure the pages are somewhere within the brakes section. I don't have the manual, which is why I'm looking for it. Maybe like brake caliper service? or seal replacement?
Anyone got a Honda manual?
Old Nov 14, 2005
i just went and rechecked both my manuals and nothing on rebuilding the caliper if i was still in school i could use ALLDATA but im not now i'm sorry i can't help any.
Old Nov 14, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
The service manual really doesn't have anything on rebuilding calipers. There is a page for Front Brake Caliper Overhaul that is basically a cut view of all the components. If you'd like I can scan and email it to you.
Old Nov 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
Here is from the manual.... If you need further info let me know i can walk you thru how to do it also. The manual dont really tell you HOW to do it so let me know!
ID:	62129   Click image for larger version
Old Nov 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
BTW you can buy rebuilt calipers fairly cheap compared to new from honda....... here a how to for bmw's basically same process...... Word of caution when they say coat with caliper greas there is a special lubricant for inside the caliper, just use brake fluid as any petroleum product inside the caliper will ruin your brake system !
http://www.bmw-m.net/TechProc/caliper.htm
Rebuilding Front Calipers
Here's the procedure for rebuilding the front calipers on an E36 M3. The procedure for the rears is almost identical, so it's not worth a separate write-up.
NOTE: Brake fluid will ruin your paint. Keep all brake fluid away from painted parts of the car!
1. Jack up the front end of the car and put it on jack stands. (There are lots of available FAQs on how to do this.)
2. Remove the wheel.
3. Remove the brake fluid reservoir cap and lay a piece of plastic film (like cellophane) over the opening and reinstall the cap. This will help create a vacuum on the fluid so that it doesn't run out the brake lines as fast. Other methods include attaching a vacuum pump to the fluid reservoir or clamping the brake line (for rubber lines only).
4. Detach the brake pad sensor wire (left front and right rear calipers). Loosen the brake line from the caliper just a little (keep it a little snug). This will make it easier to remove in later steps.
5. Remove the caliper spring clip on the outside of the caliper by prying it off with a screwdriver.
6. Remove the two black plastic covers from the caliper guide bolts on the back side of the caliper.
7. Using a 7 mm hex key or hex socket, remove the two caliper guide bolts.
8. Pull the caliper off the rotor. (There is no need to press the piston back into the caliper, since you will be removing the piston.) Pull the brake pads out of the caliper.
9. Remove the brake line from the caliper and plug the end of the brake line with a rubber vacuum cap to keep the fluid from draining out. (Place a small dish under the caliper and brake line to catch any leaking brake fluid). To keep the brake line from twisting, you may need to rotate the entire caliper as you loosen the brake line.
10. Place a piece of wood (about 1/2-1/3 inch thick) between the caliper piston and the outer flange of the caliper. Insert an air nozzle into the brake line hole and using low pressure compressed air, force the piston out of the caliper. (Be careful! The piston will pop out with a lot of force. This is why the piece of wood is there. Keep your fingers away from the piston!)
11. Remove the piston and clean it in brake fluid. Use a Scotchbrite pad to clean any crud off the piston. Inspect the outer face of the piston for corrosion or pitting. If you find either of these, the entire caliper must be replaced -- you cannot buy the piston separately.
12. Remove the outer dust cover (if it hasn't already fallen off).
13. Remove the inner rubber O-ring. It sits in a groove inside the caliper's piston housing.
14. Clean the inside of the caliper piston housing using a Scotchbrite pad, an old toothbrush, and brake cleaner. Make sure you thoroughly clean all the grooves inside the caliper. This a good time to clean the entire caliper with brake fluid (and maybe paint it). Check the inside of the caliper for corrosion and pitting. Let the caliper and piston air dry.
15. Open the caliper rebuild kit. You'll find two parts: an internal sealing O-ring and an outer dust boot.
16. Coat the inner O-ring with either caliper grease (this is a special grease just for calipers - available at most auto parts stores) or brake fluid. Coat the inside groove of the caliper (where the O-ring will sit) with the same. Install the internal O-ring by pressing it into place with your fingers.
17. This next step is the hardest part of the whole procedure. Coat the outside of the piston with either caliper grease or brake fluid. Pull the rubber dust cover over the INSIDE edge of the caliper, with the lip of the dust cover (the lip that will be inserted in the caliper, not the piston) facing away from the piston. The edge of the dust cover that will eventually be seated in the groove on the piston should be facing the piston groove, and the rest of the dust cover should be hanging slightly over the edge of the piston. While holding the piston near the caliper housing, push the lip of the dust cover into it's groove in the caliper. Then gently push the piston into the caliper. The piston will hit the inner O-ring and become more difficult to press in. Keeping the piston exactly straight, gently tap it into place using a hammer against a flat piece of metal or wood held against the piston. You can also insert the handle end of a small hammer into the piston and then push the piston into the caliper.
18. You can skip this next step, but it will make it easier to bleed the caliper because it primes it with brake fluid. Loosen the caliper bleed screw and using either a vacuum on the bleed screw or pressure on the brake line hole, fill the caliper with brake fluid. (I use a Mity-Vac pump to pull fluid into the caliper.)
19. Reattach the brake line, insert the brake pads into the caliper, and install the caliper on the rotor. (Don't tighten the brake line yet - just a little snug.) Again, it may be necessary to rotate the entire caliper as you tighten the brake line in order to keep the brake line from twisting.
20. Reinstall the caliper guide bolts (torque to 24 ft lbs.), plastic covers, and spring clip. Then tighten the brake line. Reattach the brake pad sensor wire (left front and right rear calipers).
21. Remove the cellophane, vacuum, clamps, etc. and bleed the caliper (there are plenty of other FAQs on how to do this).
22. Remount the wheel and lower the car off the jack stands. Remember to pump the brake pedal a few times to get the pads reseated against the rotor before you go for a test drive.
Bob Stommel
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Tim1959
Jun 3, 2015 08:15 PM
bsmiley
Apr 27, 2015 01:27 PM
