need help with my halo headlights
Old Nov 14, 2005
Mr. Fantastic's Avatar
Mr. Fantastic is an unknown quantity at this point
i just changed my stock headlights on my 04 civic with some halo projector lights this weekend. There was one cable that has a black/red wiring and i did not connect them because i didnt know what it is for, but eveything is working properly. Does anyone know what it is for? Do i need to connect it? Also, the right headlight seems to be pointing higher than than the left. How do i adjust the bulb? Also.....where can i get replacement clips because most of mine broke off when i was removing the front bumper and cant find them in any auto parts store. please help. Thanks.
Old Nov 14, 2005
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
hmmmm..............i think those wires are for the halo rings inside ur headlights u dun really need it unless u want those rings to light up. Im not sure how to do that. U can adjust it by adjusting the projector lense there should be a screw for that, since its aftermarket it might not be protected by a plastic peice and for the replacement clip i have no idea....ebay?
Old Nov 14, 2005
i am gonna try to wire them tommorow , just wondering if there is any way to get in there without having to take out the bumper all over again.
Old Nov 14, 2005
what? well i dun think u have to take off ur bumper , is the headlights installed already? if it is u just have to connect the wire just need to remove ur bumper to install the headlight. Im not sure how to connect the wire but i think u just shave a wire and connect it i seen people have it on but not the low beam on so i guess theyd connected it to that bulb with the 194 bulb. the wires should be in back of the headlight so just pop ur hood unless its different then other angel eyes.
Old Nov 14, 2005
ramcosca's Avatar
Words on a User Title
The clips you can get them at your local Honda dealer.
Get raped for a tiny piece of plastic! Yay!
Old Nov 14, 2005
pyrovince's Avatar
pyrovince is an unknown quantity at this point
Well if the headlights work fine, thats half the battle. As for the other wires, they are probably for the angel eyes/halos. If you are not sure you could wait till dark, and put a 9 volt battery to the black and red wires just to see what lights up before you go splicing and switching. If the extra wires are for the halos all you need is some wire, 18 or 12 guage stereo wire works. Connect both of the red wires together, both of the black wires together. Basically this is so the halos are in parallel and getting the same amount of voltage. Then connect the wire that connects the red wires together to the positive battery terminal. Then, in a short explination, connect the wire that connects the black wires together to a switch, then the output of the switch to the ground terminal. So basically you wire the halos in parallel and put the switch that prevents current flow on the ground wire. Again, all of this is if the extra wires are for the halos.
Here is a diagram that might help.
- <neg battery terminal
~ <switch w\ 1 input and 1 output
| | <black wires
O O <halos
| | <red wires
+ <positive battery terminal
Someone correct me if i am wrong.
Old Nov 14, 2005
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
^^^^ or just splice into ur park/city lights that wut i did forsome1s 02 duals.
Old Nov 14, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
^^^ thats what i did when i had mines....
Old Nov 14, 2005
i'll give it a try
Old Nov 14, 2005
ramcosca's Avatar
Hey, when you're done: can you post up some pics of the ride with the halos? Day pictures and night pictures appreciated. Will be +repped!
Old Nov 14, 2005
pyrovince's Avatar
Around here to local police don't really like anything nice, so i try to stay more on the legal side.
Old Nov 15, 2005
thanks for the help guys, ill try to post some pics soon
Old Nov 15, 2005
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
| | <black wires
O O <halos
| | <red wires
Your correct if they need to be on a switch, but he could just connect them to the wires that control when the headlights are on this way they go on together.
Old Nov 15, 2005
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i just wired mine into to the harness for the parking lights. it's for the halo worked like a charm and haven't blown a fuse yet as for the clips, you may be able to find some slightly diff universal ones at autozone or advance or something, otherwise, you'll have to get raped at the dealer for like 2 bucks each!!!
Old Nov 15, 2005
ok here it is , got some pics
here it is
Old Nov 15, 2005
did, all you have is thumbs....
Old Nov 16, 2005
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
where did you get ur halos from?
Old Nov 16, 2005
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
ya where did you get those projectors from? ebay? they look pretty good, any foggage problems yet?
Old Nov 16, 2005
dirtySAMURAI's Avatar
I log in from time to time
they're from ebay.
Old Nov 18, 2005
Physpher's Avatar
Physpher is an unknown quantity at this point
Hi guys dont post here often but eh...
i have some sonar halos, from ebay. i turned the rings blue and after i re-sealed them, i get no fog. im happy, well except the left headlight is way up high and to the left and the right is very low and to the left.
Sorry Some of the pics are blurry, wrong pic mode.
ID:	62227   Click image for larger version
Name:	Night Heads.JPG
ID:	62228   Click image for larger version
ID:	62229   Click image for larger version
Old Nov 18, 2005
ramcosca's Avatar
Originally Posted by Mr. Fantastic
here it is
Thank you! When you get bigger-size/higher-resolution pics, could you PM them to me? Thanks!!
Old Nov 18, 2005
ramcosca's Avatar
Old Nov 18, 2005
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
hey infinite012, where'd u get ur proejectors and rings from?
btw, how's sang doing and what car does he drive now? lol. wreaks a Z and now he drives a benz. juss wondering what was next on his list =)
Old Nov 18, 2005
i am starting to get some fogging but not much ...how do i go about clearing them..........?
Old Nov 18, 2005
Ser1N's Avatar
EK Hatch
Ser1N is an unknown quantity at this point
Reopen them , clean it out and reseal them~
wingsfan19
Oct 1, 2015 03:45 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
