tranny
Old Nov 6, 2005
zach_04LX's Avatar
zach_04LX is an unknown quantity at this point
tranny
I have been reading up on people doing AT/MT swaps, and I have decided to swap mine. However, people have been saying that the entire transmission costs around $600, and I haven't found one. I don't really know where to look. Can someone point me in the right direction for finding all the parts I need? Is there a certain site that I can get everything?
Old Nov 6, 2005
turboengnr's Avatar
DONT PANIC
go to a junk yard.
you need the transmission, slave cylinder, flywheel, clutch, pressure plate, master clutch cylinder, clutch peddle assembly, hyd. lines from master to slave cylinder, shifter cables, shifter assembly
i have the shifter cables, so PM me if you cant find them
Old Nov 6, 2005
hk2ronin's Avatar
hk2ronin is an unknown quantity at this point
junkyards a good idea, you can try cherryauto.com or car-part.com if u wanna try online sources. You could also do a search online and alot of online salvage yards will pop up.
Old Nov 6, 2005
zach_04LX's Avatar
I was thinking about cherry-auto.com for the transmission itself. I figure a used transmission that's in good condition would be better than spending $2500 on a new one. Then I will have more money to spend on things like a better clutch and flywheel, etc. Any places you can recommend for the smaller parts like the subframe, motor mounts, etc.?
Old Nov 7, 2005
meseetree's Avatar
meseetree is on a distinguished road
don't forget about the ecu and having it flashed for your car by honda.
you can do the whole thing for under a grand if you just look.
Old Nov 7, 2005
zach_04LX's Avatar
Alright, you say I can do it for under a grand, but nobody can seem to tell me where to get parts. I found the tranny that I'm probably going to get for $600, but it doesn't come with anything else.
Old Nov 8, 2005
turboengnr's Avatar
DONT PANIC
why do you have to have anything done to the ecu?
Old Nov 8, 2005
robbclark1's Avatar
Retired suspension supermod.
Dude, it seriously isn't worth it. Not only do you need the parts that turboengnr said, but you need an ECU. The ECU is needed because it is programmed to shift for an automatic. When it senses a manual transmission, it won't know what to do. But then again, I don't know much about ECUs, so I am going off my limited knowledge.
It will cost you at least $1500 not with install. But it is your money, not mine.
Old Nov 8, 2005
zach_04LX's Avatar
Does anyone know whether or not the parts that I need can be from any 7th Gen or does it have to be from an 04 LX? Things like the subframe and axels. Some of the parts I'm going to buy from Honda, but others I'd like to get from a junkyard and I just needed to know if all the years and models would work.
Old Nov 8, 2005
djmota's Avatar
1500 for about 15-20whp That sounds about right. It would probably be cheaper if you could source a local junk yard and get all the parts from the same place.
Old Nov 8, 2005
HondaLuver's Avatar
Its a celebration bitches!
the ecu will not be hooked up to the auto tranny anymore. so basically you wont worry about that.
just keep your stock ecu, it will work, search, there have been threads about it, and that person kept their stock subframe and auto ecu, it worked perfectly
Old Nov 8, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
yea. don't need ecu. u can use ur auto ecu. it will just throw cel.
Find a junkyard w/ wrecked civic. just pull the parts urself. it is cheaper.
Old Nov 8, 2005
zach_04LX's Avatar
That's what I'm thinking about doing. I just need to know if I HAVE to get parts from an 04 LX or if I can get parts from a different year and model. Does anyone know?
velozp
Dec 13, 2015 11:28 AM
mistahlorax13
21
Nov 18, 2015 12:47 PM
speedlever
Sep 24, 2015 07:18 PM
FistRock
Sep 4, 2015 08:00 PM
dantheman42
Sep 4, 2015 01:10 PM
