wiring diagram
Old Nov 2, 2005
chinkst3r's Avatar
chinkst3r is an unknown quantity at this point
wiring diagram
hey guys, i got an o3 lx and i need the wiring diagram for it, i plan on installing some neons that will light up wen the door is opened...i dont wunna tap into the dome light because that would be too much of a hassle...ne ideas where i can get a free wiring diagram, i found one before but cant be able to find it again... i already tried the search button but for some reason, its not working, on neither of my computers... thanx in advanced
Old Nov 3, 2005
chai_dst's Avatar
chai_dst is an unknown quantity at this point
Just tab WHT/BLU(+) and GRN/RED (-) from the dome light.
The easy way you should tab it from A pillar (Driver side).
It should be working.
Old Nov 3, 2005
that doesn't work. i tried all of them and the only way was running the wire all the way to the dome bulb.
Old Nov 7, 2005
chinkst3r's Avatar
naw i found it...down under the steering wheel theres a green pin connector for the stock alarm system they use, theres three wires for the door and they are negative, so ima just use that and a relay to make it happen...thanx for the help though
juror
Suspension DIY
Jul 30, 2019 03:28 AM
rman1900
21
Sep 10, 2018 04:52 PM
sch2cm
Jul 21, 2015 09:58 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
robbie374
Jul 7, 2015 02:56 AM
