Remote Trunk Release
Old Oct 28, 2005
thw_goalie's Avatar
thw_goalie is an unknown quantity at this point
The previous owner of my car had a remote starter installed in the car, so he got a new remote with that when it was installed. The new remote has buttons for Lock/Unlock, Remote Start, and Trunk Release. All the buttons work except for Trunk Release. Also, my factory remote doesn't work at all anymore (they must of changed all the wiring around.)
Someone on another site tried to help me out before, but it involved using a relay and changing the wiring, and it didn't really make sense that it would make the trunk release work, so I didn't go through with it. I've attached the .pdf file he sent me for what wires I was supposed to change around. If that actually would work, could anyone explain to me how?
PDF file is here.
Here is what he wrote in his email...
"There should be a blue wire coming out of the unit. This is the trunk release. To test it use a multimeter and test for ground when you push and hold the trunk release. If this works follow the instructions on the wiring diagram for the trunk release."
If that doesn't make sense and won't work, does anyone know how I could make it work?
Old Nov 5, 2005
Macko's Avatar
Macko is an unknown quantity at this point
civics don't have power trunk release you have to install a trunk solenoid to mechanically pull on the trunk cable to realease it, just hook up the solenoid to any Auxillary channel on the alram
Old Nov 5, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
does your trunk lid look like this:
or this:
1st one: no electric opener
2nd one: you guessed it, you do
Old Nov 6, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
This might help.
Old Nov 6, 2005
booba5185's Avatar
^^^yea that show u how to get one if u dont.
Old Nov 9, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
that diagram is for interfacing into a oem power trunk release. Your going to either need a trunk pop solenoid or the Accord trunk latch like the one thats in the picture. I have the accord trunk latch and it works great and looks stock. The trunk pop solenoids are a PITA to install, and they look ugly.
If you go with the accord trunk latch, your going to need to feed it to 12 volt signal for it to operate.
Pin 85 12 volts constant
Pin 86 trunk release output from your RS/alarm
Pin 30 Wire going to trunk release
Pin 87 12 volts constant
If your alarm/RS brain outputs a positive signal for the trunk pop, ground pin 86 and put the output on pin 85
Old Nov 9, 2005
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
Is there anyway to interface that setup with a factory remote with the trunk release on it?
Old Nov 9, 2005
dariusld's Avatar
I don't think so. There are other threads on the subject though,search.
Old Nov 9, 2005
you'll need to swap out the keyless entry unit like the DIY for using a crv keyfob . The civic keyless entry unit doesnt have an auxilary channel. You could set it for each time you unlock your doors, the trunk will pop, but thats not really a good idea.
Old Nov 9, 2005
thw_goalie's Avatar
Thing is, it's an Acura El, not a Civic. It's already set up for trunk release, but the new remote I have doesn't work with it.
Old Nov 9, 2005
directtechs doesnt have the wiring charts for an el, probably because its so close to the civic. Does the trunk release work with the OEM keyfob? if it does go to the trunk release and use a DMM to figure out if the release takes a positive or negative signal to operate.
Old Nov 11, 2005
thw_goalie's Avatar
No, it doesn't work anymore with the OEM remote. They must of changed the wiring around when they installed the remote start.
Old Nov 11, 2005
hmm
if you can get a hold of a DMM, see if theirs continuity to ground with the wire thats coming from the trunk latch
SammySC
121
Apr 7, 2017 07:43 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
nixyfior
Sep 14, 2015 08:32 PM
