Small green bulb in fog light / cruise toggle switch
Old Oct 28, 2005
clueo8's Avatar
clueo8 is an unknown quantity at this point
I have been searching all over the internet to find replacements for the very small bulbs which go in things like the toggle switch for a fog light which turns green when the fog lights are turned on. Or the little green light on the cruise control toggle. I have a 02 Civic EX, but I imagin these bulbs are used in older and newer models. Does any one know where I can buy these things? Radio shack doesn't sell em... I'm pretty sure they are honda specific.
a picture is at website:
my.win.psu.edu/tlk223/bulb.jpg
Sorry, couldn't post the pic on the post, I'm too much of a newb to do so.
Old Oct 28, 2005
streetglower's Avatar
you can get those small lights at the honda dealership or www.hondaautomotiveparts.com
Old Oct 29, 2005
FALKEN's Avatar
Civicforums Junkie
moved
Old Oct 29, 2005
i just took mine out cause i don't like green. But you can just get a small bulb and put it on. they install by bending the bulb wires around the old base. very easy.
Old Oct 29, 2005
clueo8's Avatar
The way the install is you put them in and turn it about 45 degrees and it locks it in. I've been searching the honda website suggested and I cannot find it anywhere! gearbox, where would I get small bulbs that fit?
Old Oct 29, 2005
CraigW's Avatar
http://www.hondaautomotiveparts.com/...atcgry5=SWITCH
Old Oct 29, 2005
clueo8's Avatar
thats the right page, but I dont think they sell just the bulbs... or even the cruise switch...
Old Oct 29, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
pick a different year. The bulbs are listed for other models. Check the part number for the switch and if they they are the same then use the bulbs listed for that model.
Old Oct 30, 2005
i can check if i have a few naked bulbs I can send you. you just gotta unwrap the old ones from the base and wrap on the new ones.
Old Nov 2, 2005
clueo8's Avatar
thanks! but I wouldnt want you to have to go through all that trouble... can't I just put up some of the bulb minus the base from a radio shack? Are they a certain voltage?
Old Nov 2, 2005
i don't think it matters. i actually had to switch out a few of mine with bigger ones when i redid the dash light color. they're fine for a month now. just get something similar thats just a bulb with wires. use the base you already have.
Old Jul 13, 2007
mikem317's Avatar
mikem317 should not be trusted
Re: Small green bulb in fog light / cruise toggle switch
Anyone have the part number for the amber bulb? Mine just went.
Old Jul 14, 2007
CraigW's Avatar
For the cruise switch:
35851-S5A-A01 = Green cover on bulb (cruise on indicator)
35850-S5A-A01 = Blue cover on bulb
My 05 sedan had a blue covered bulb for illumination, I changed it to green to better match the mirror switch illumination.
Amber may be achieved by removing the condom cover from one of these bulbs listed (the cover will most likely rip when removed)
cukaracha
May 16, 2015 02:11 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
disaster
Nov 7, 2001 05:30 PM
