Easiest way to un do alarm?
the alarm is not working right, what's the easiest way to undo it do that I can just use the key to open doors and drive and look door manually?
battery disconnet?
battery disconnet?
go under your steering wheel and open up the plastic cover to where your legs be. your alarm brain should be under there. its like a rectangle black box. just unplug it and you should be good to go.
Crayons taste like purple...
battery disconnet?
battery disconnet?
if you unhook batt...you won't be able to start the car...I wonder if by unhook you meant while not using the car...you could lose engine codes and stuff like memory in the car.....just find the power wires for the alarm....snip.snip. or just take out the fuse....
JetsterDajet
52
May 8, 2016 12:11 AM
frank_kleng
Sep 29, 2015 10:55 PM
hondacivic0253
Sep 29, 2015 08:06 AM
MamaBear2015
Sep 24, 2015 11:34 AM
