Easiest way to un do alarm?
Old Oct 23, 2005
chicohonda02's Avatar
Since 2002 Baby!
Question Easiest way to un do alarm?
the alarm is not working right, what's the easiest way to undo it do that I can just use the key to open doors and drive and look door manually?
battery disconnet?
Old Oct 23, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
go under your steering wheel and open up the plastic cover to where your legs be. your alarm brain should be under there. its like a rectangle black box. just unplug it and you should be good to go.
Old Oct 23, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
battery disconnet?
if you unhook batt...you won't be able to start the car...I wonder if by unhook you meant while not using the car...you could lose engine codes and stuff like memory in the car.....just find the power wires for the alarm....snip.snip. or just take out the fuse....
Old Oct 23, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
pull all the fuses from the alarm brain.
JetsterDajet
52
May 8, 2016 12:11 AM
frank_kleng
Sep 29, 2015 10:55 PM
hondacivic0253
Sep 29, 2015 08:06 AM
MamaBear2015
Sep 24, 2015 11:34 AM
First Car
Sep 8, 2015 08:54 PM
