Question about Vp Civic
Old Oct 22, 2005
Spracto's Avatar
Spracto is an unknown quantity at this point
Hey I got a really tricky question for those who know how the different forms of VTEC work. ok so my friend has a 2k5 civic vp. That civic doesn't have vtec at all. It's still a d17 but does having no vtec mean it has no vtec-e? as in vtec economy? I know that the economy version of vtec comes in most civics and base RSX's too. It shuts off two valves at low rpms thus making your car a 14 valve car. If the civic VP has no vtec? does that mean all 16 valves are moving at all times?
Old Oct 22, 2005
Al Gore FTW's Avatar
jdmtytedoridori
its a d17a1, which comes in the dx/lx/vp. no vtec.
Old Oct 24, 2005
Spracto's Avatar
I know it doesn't have vtec
What I'm asking is:
Since the VP doesn't have vtec does that mean all 16 valves are engaged all the time? I know my lx has vtec-e which means only 12 valves are running at low rpms which saves gas. But with no vtec at all the VP shouldn't do that right?
Old Oct 24, 2005
ramcosca's Avatar
Words on a User Title
Uhm... LX doesn't have VTEC-e...
EX's have VTEC-e...
They ust mention it as VTEC, so as not to get you confused.
If it were i-VTEC, for example, they would specify it, since i-VTEC is better than VTEC, performance-wise...
VTEC-e isn't any better than VTEC, performance wise...
Old Oct 27, 2005
Spracto's Avatar
OK I'm still not getting my question answered here.
What I'm asking is this:
Vtec-e shuts off a cylinder effectively making your civic a 12 valve car at low RPMs. This nets better gas mileage is day to day driving.
Because certain models of civic don't have vtec-e, does that mean that they run as 16 valve cars all the time?
Old Oct 27, 2005
streetglower's Avatar
Ok, Vtec-E does not shut a cylinder off. Yes the car runs on 12 valves at low RPM. and as RPM increase, at a certain point set by the computer, a signal is sent to open a spool valve which directs oil pressure to a mechanical sliding pin. the pins lock the rocker arms actuating the valves to the follower on the high RPM cam lobe.
Now if the car doesnt have any vtec, then yes all 16 valves work all the time.
Old Nov 1, 2005
ramcosca's Avatar
Ah, so that's how it works. Thanks for the explanation.
Old Nov 2, 2005
Spracto's Avatar
THANK YOU! So not having vtec-e technically could be beneficial (in terms of speed) since all the valves are engaged. I like the thought of that.
Old Nov 3, 2005
johnbt23's Avatar
^ u got it
Old Nov 3, 2005
Spracto's Avatar
noice! That makes me really happy. Thanks again street glower.
I don't have vtec-e, and i'm damn proud of it....
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
MooCoW
Nov 9, 2001 05:22 PM
colombianDXcivic
Bolt-on Engine Performance
Nov 8, 2001 12:14 AM
