Question about Vp Civic
Rep Power: 0 Question about Vp Civic
Hey I got a really tricky question for those who know how the different forms of VTEC work. ok so my friend has a 2k5 civic vp. That civic doesn't have vtec at all. It's still a d17 but does having no vtec mean it has no vtec-e? as in vtec economy? I know that the economy version of vtec comes in most civics and base RSX's too. It shuts off two valves at low rpms thus making your car a 14 valve car. If the civic VP has no vtec? does that mean all 16 valves are moving at all times?
Rep Power: 0 I know it doesn't have vtec
What I'm asking is:
Since the VP doesn't have vtec does that mean all 16 valves are engaged all the time? I know my lx has vtec-e which means only 12 valves are running at low rpms which saves gas. But with no vtec at all the VP shouldn't do that right?
What I'm asking is:
Words on a User Title
Rep Power: 311 Uhm... LX doesn't have VTEC-e...
EX's have VTEC-e...
They ust mention it as VTEC, so as not to get you confused.
If it were i-VTEC, for example, they would specify it, since i-VTEC is better than VTEC, performance-wise...
VTEC-e isn't any better than VTEC, performance wise...
EX's have VTEC-e...
Rep Power: 0 OK I'm still not getting my question answered here.
What I'm asking is this:
Vtec-e shuts off a cylinder effectively making your civic a 12 valve car at low RPMs. This nets better gas mileage is day to day driving.
Because certain models of civic don't have vtec-e, does that mean that they run as 16 valve cars all the time?
Rep Power: 429 Ok, Vtec-E does not shut a cylinder off. Yes the car runs on 12 valves at low RPM. and as RPM increase, at a certain point set by the computer, a signal is sent to open a spool valve which directs oil pressure to a mechanical sliding pin. the pins lock the rocker arms actuating the valves to the follower on the high RPM cam lobe.
Now if the car doesnt have any vtec, then yes all 16 valves work all the time.
