Tokico Hp
Old Oct 19, 2005
WEAPON-R CIVIC's Avatar
WEAPON-R CIVIC will become famous soon enough
Tokico Hp
yesterday i had tokico hp shocks installed on my 01 civic ex, have neuspeed sportline springs with spc camber kits, really smooth ride, but!! since the install I'm getting this noise, not popping but tapping from passenger side, a little from driver side, the guy who installed them, been installing shocks, struts, springs for quite some time doesn't understand the noise, some have told me to wait for a week, sometimes the rubber gets pinched, some have said alignment, diddn't have the noise with stock shocks, any help would be greatly appreciated, noise is driving me crazy
Old Oct 20, 2005
thecheat's Avatar
thecheat is an unknown quantity at this point
Front or Rear. If its front maybe try some White lithium grease between the top of the strut and the body. If rear you might have the springs in a little out of allignment. I have had both and it makes a noise like you are describing.
Old Oct 20, 2005
rear, you mean rear alignment
Old Oct 20, 2005
rear, you mean rear alignment? I think I'll take the car and have it aligned to see if this gets rid of it, thanks!!!
Old Oct 20, 2005
PunkingCivic's Avatar
I need TP for my bunghole
I'd double check that all the bolts are tight in the engine bay that hold the strut to the body adn the hat to the spring.
I had that noise once and that is what it was.
Old Oct 20, 2005
MIVtec's Avatar
MIVtec is an unknown quantity at this point
make sure your tie-rod endlinks aren't shot those can cause some disturbing noises as well.
Old Oct 20, 2005
thanks all,will def check into it!!!
Old Oct 20, 2005
scatman's Avatar
Still in the game...
check all the tightness of the bolts.
Old Oct 20, 2005
thecheat's Avatar
you should have it alligned anyway but thats not what I'm talking about. The spring can get rotated on the shock body and when it compresses the end of it taps the small depression where it is supposed to rest. I had my whole right LCA off once trying to figure out what it was then a Tech friend of mine grabed the spring and gave it a real hard twist and the problem went away.
Old Oct 20, 2005
dapakione's Avatar
dapakione is an unknown quantity at this point
My bolts were loose in the front i had to tighten them and the noise i heard went away, ( i think it was mental for some reason tho )
reqy
Jun 1, 2015 07:05 AM
CarbonFly
May 17, 2007 04:06 PM
jedo
May 27, 2003 07:17 AM
xblkcivicx
23
May 12, 2003 06:53 PM
Nuts
Bolt-on Engine Performance
24
Sep 25, 2002 07:25 AM
