7440 wont fit properly in 7443 wtf
Old Oct 18, 2005
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
i went to the honda dealer and bought the 7440 SiR turn bulb, but its not sitting tight in the socket, what shall i do, i think it hold but its not tight like a regular one, is wobbly...
people said they cut a piece of plastic, if so, where thx.
Old Oct 18, 2005
saugashan's Avatar
ok figured it out, and ill never u tell u ..bahahahaha
jkin, jus had to bend the pins
Old Oct 19, 2005
FALKEN's Avatar
Civicforums Junkie
moved
Old Oct 19, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
bend the pins? my way of doing it is to cut a part of plastic on the inside of it so that the 7440 bulb can fit because the 7440 has a ridge that blocks it from going in. therefore cutaway a piece from the T20 socket and the bulb fits nice and tight.
Old Oct 19, 2005
civicPesek's Avatar
civicPesek is an unknown quantity at this point
do you cut the plastic thing on the bulb or the socket?
how do you cut the piece from the socket? using what tools?
i thought the turn bulb from an SI will fit plug n play into our socket?
Old Oct 19, 2005
Xenin's Avatar
well after working on it today theres a little more that needs to be done. you need an exacto knife and a nail file. part of the inside plastic on the socket stops the bulb from going down further. use the exacto knife to cut part of it away. if you dont know what i mean, insert the bulb into the socket and you'll see it wont go in further on one side. then using the nail file, file away at one of the ridges on the bulb so that its trimmed down. should fit snug into the socket now.
Old Oct 20, 2005
civicPesek's Avatar
hey does the socket for sedan and coupe different from each other? because one member i know, he's from canada and he has the amber bulb from SiR and he said it fits fine for him without any modification to his socket. he has a coupe, what do you all have? i have a sedan and haven't try this yet.
Old Oct 20, 2005
Xenin's Avatar
yes, the coupe and sedan socket are different.
GritzNGravy
Aug 19, 2015 03:03 AM
TheRubixHorse
Jul 29, 2015 05:22 AM
beeemerdude
Jul 23, 2015 03:53 PM
EM_WON
Jul 22, 2015 06:49 PM
stvpagn
Jul 9, 2015 09:59 PM
