ITB's {dun dun dunnnnn)
Old Oct 18, 2005
TheSmuggler's Avatar
So who thinks, or knows, that ITBs will fit into the engine bay after a k20a2 swap. I figure that maybe a little of the hood support and the front support bar may be in the way, but could be shaved down a little. Thoughts, comments, flame suit?
Old Oct 18, 2005
PunkingCivic's Avatar
I need TP for my bunghole
I think it will fit.
One person did the swap and crammed a jackson racing super charger in there.
There might be hodd clearence issues.
Here is a side shot of some throttle bodies in a rsx.
pix from www.twminduction.com
Old Oct 18, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
Damn smuggler I was just thinking of calling you as I looked through the list of numbers I ogt in my phone because I'm in the process of getting a K20A2 swap that I'm gonna sell. Tell civic rida, maybe he'll budge. lol
Old Oct 18, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
o i c, you mean serperate throttle bodies for each cylinder! ive seen preludes with superchargers do it. ive seen hot rods with it. i believe you could pull it with a k20. i never understood the need for the serperate ones compared to the one main TBI. you would think to just get a bigger bore or something. no flaming, good thought though. anyone care to answer my q?
Old Oct 18, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
it gets rid of most the restriction on the intake. it doesnt always add power. typically you shouldnt do it unless your heavily modded otherwise its a waste of money. the main reason to do it is because it looks cool.
Old Oct 18, 2005
turboengnr's Avatar
DONT PANIC
it gives instant throttle response. Basically it negates the need for plenum area. It is made for high reving applications. The low end torque is usually not up to par when mated with short runners, but you can modify the runners to make it perform where you want it.
Old Oct 18, 2005
dre2600's Avatar
I thought I saw someone retrofit ITBs from a street bike (GSXR?) onto a B16? or B18? I don't know how well that go over w. the K20 owing to the extra power/displacement, but just a thought. Also, does TODA make ITBs for the K20, I think they have a set for the F20? or at least a set in development.
Old Oct 19, 2005
I know that they fit inside an RSX, I guess a better question was how differn't are the hood/ front support bars in our cars vs the type-s. If they were pretty much the same then we would be ok. The ITB would be the last thing done after a full toda install, including n2 camshafts, their N/A kit (pistons and all), kpro, new IM and the such. It was a question for the final step of a full n/a build. I don't need to kow about ITB's, my question was for clearence.
Old Oct 19, 2005
iamboo's Avatar
Retired - SoCal FI Mod
a buddy of mine from honda tuning magazine retro'd some gsx-r ITB's onto his D16.... it made just as much power as our d17 running 4 pounds of boost....
Old Oct 19, 2005
Ok great, this is just about clearence guys...
Old Oct 20, 2005
iamboo's Avatar
then... yea it'll fit... just drive without a hood for a while or make speed holes on the hood...
Old Oct 20, 2005
So in other words you don't know for sure? It seems since the TWM ones fit a stock RSX they should fit ours, maybe after a little shaving.
Old Oct 20, 2005
4bangin's Avatar
ya the main reason is because it looks soooo ****ing cool!
Old Oct 20, 2005
Only down size is that it responds to temp changes 4 times as bad as a normal intake...
Old Oct 20, 2005
HondaLuver's Avatar
Its a celebration bitches!
humm... i would do this if it was a strip/track car..
Old Oct 20, 2005
Yeah... I'm stuck on it for a street car for some reason though....
Old Oct 20, 2005
XxJDMCivicxX's Avatar
Have fun running itbs without a decent ems and they'll be lots of fun to tune . Just some extra $$$ to think about. You can retrofit, itbs of bikes onto cars yes but you need some welding skills as you need to cut the middle of the itb to make measures. No big problems but don't think it's near bolt-on.
Old Oct 20, 2005
ITB's would be the last on my list, if I went through with it. KPRO, N2 cams, ITB's and Toda Race header.
Old Oct 25, 2005
Bump for more discussion on fitment issues
RW_Blaze
Nov 20, 2003 02:11 PM
AdamYYZ
Sep 13, 2003 05:51 PM
