Short ram problem
Old Oct 14, 2005
swifty2k's Avatar
swifty2k is an unknown quantity at this point
Short ram problem
My local dealer installed my ractive short ram about a month ago. They set it up so theres 2 lines running over it, a fuel line which has a heat thing around it...and another one, which Im not sure about. Anyways, this mistery line is starting to stick to the intake, I moved it the other day, and theres residue from the line stuck to the intake I think im going to go buy a heat wrap shield thing, similar to the fuel line (I dont like having a fuel line that close to that much heat...)...But this ever happen to you guys? I was going to remove it, and run the line underneath the intake, but it looks like there would be too much slack...
I didnt think intakes got that hot! time for a heat shield i guess
Old Oct 15, 2005
Jrfish007's Avatar
Take it back to the installer and show them, maybe they'll put something around that line for free...
Old Oct 15, 2005
streetglower's Avatar
can you take a pic. I used to have a short tam intake and never had that problem. Sounds like they didnt route the lines correctly. That other line may be a vacuum line. But not sure.
Old Oct 15, 2005
mine has a rubber thing around it. maybe yours does too but you just need to clean it? so it won't leave residue?
Old Oct 15, 2005
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
i got same intake as u, my lines run under the bottom of the intake
Old Oct 15, 2005
RonZ's Avatar
RonZ is an unknown quantity at this point
I have the same intake and same problem, I just dug up a piece of plastic tube looking thing, kinda like a really small PVC pipe and wrapped it around that wire.. works fine for me.
cukaracha
May 16, 2015 07:36 PM
Aznnp77
Dec 26, 2001 10:38 PM
lapchern
Bolt-on Engine Performance
Dec 22, 2001 06:23 PM
MyOtherRideIsBritney
Dec 14, 2001 04:05 PM
HuDaThaN
Nov 18, 2001 09:27 PM
