need help wiring sidemarkers!!
Old Oct 12, 2005
spoonEM's Avatar
omgwtfbbq mod.
I did like the DIY said, black wire to ground, and green wire from sidemarker to the red wire since I want them on with daytime lights AND turn signal, however, they did not turn on, when I wired up the red AND the green to the green on the sidemarker, they go on, but cause my turn signals to stay on at all times as well. Anyone know what Im doing wrong? any help would be appreciated and rep will soon follow.
Old Oct 12, 2005
You're confusing me. Your sidemarker has two wires. For always on, hook one to ground and one to red (parking light). For only blinking, hook one to ground and the other to green (signal). For both, hook one to red and the other to green. then they do both except when the lights are on, they will flash alternately with the front signal.
Old Oct 12, 2005
spoonEM's Avatar
omgwtfbbq mod.
ok, heres what i have. I have an 05 civic, so on the signal bulb, I have 3 wires coming off of it. One is ground, and then i have red and green. Now, on the sidemarker, I only have 2 wires, ground and green. When I hook up ground from sidemarkers to ground on signal harness, and then green from sidemarker to red on car harness, nothing happens. So I tried hooking up both red and green from car to green on marker, but it causes the turn signals to always be on. I know Im doing someting wrong, just not sure what it is yet.
Old Oct 12, 2005
TemjinX2's Avatar
gear box seems pretty clear on his directions. Basically the red wire is the parking light wire and the green wire is the turn signal wire.
If you want them on all the time, connect the hot wire from your sidemarker to the red wire and the ground wire to the green wire. This way, your sidemarker turns on with your parking lights and signals alternatively with your turn signal.
if you want them just to turn on with the signal. Then your hot wire from the sidemarker to the green wire and the ground to the black wire on the car.
If this doesn't work, make sure your connections are good if your using wire taps. Make sure you have the correct wire for + and - as well.
Old Oct 12, 2005
spoonEM's Avatar
omgwtfbbq mod.
thank you sooo much for clearing that up, i know what i did wrong now....thanks alot guys!!!
Old Oct 12, 2005
TemjinX2's Avatar
cool. good luck. Post pics when your done. There pics of my side markers on the lighting forums or you can view it on "my rides" link.
SimpleUser
Apr 24, 2021 02:54 AM
Misfit2613
Jul 30, 2015 09:49 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
