need help wiring sidemarkers!!
omgwtfbbq mod.
Rep Power: 288 need help wiring sidemarkers!!
I did like the DIY said, black wire to ground, and green wire from sidemarker to the red wire since I want them on with daytime lights AND turn signal, however, they did not turn on, when I wired up the red AND the green to the green on the sidemarker, they go on, but cause my turn signals to stay on at all times as well. Anyone know what Im doing wrong? any help would be appreciated and rep will soon follow.
Rep Power: 788 You're confusing me. Your sidemarker has two wires. For always on, hook one to ground and one to red (parking light). For only blinking, hook one to ground and the other to green (signal). For both, hook one to red and the other to green. then they do both except when the lights are on, they will flash alternately with the front signal.
omgwtfbbq mod.
Rep Power: 288 ok, heres what i have. I have an 05 civic, so on the signal bulb, I have 3 wires coming off of it. One is ground, and then i have red and green. Now, on the sidemarker, I only have 2 wires, ground and green. When I hook up ground from sidemarkers to ground on signal harness, and then green from sidemarker to red on car harness, nothing happens. So I tried hooking up both red and green from car to green on marker, but it causes the turn signals to always be on. I know Im doing someting wrong, just not sure what it is yet.
Rep Power: 296 gear box seems pretty clear on his directions. Basically the red wire is the parking light wire and the green wire is the turn signal wire.
If you want them on all the time, connect the hot wire from your sidemarker to the red wire and the ground wire to the green wire. This way, your sidemarker turns on with your parking lights and signals alternatively with your turn signal.
if you want them just to turn on with the signal. Then your hot wire from the sidemarker to the green wire and the ground to the black wire on the car.
If this doesn't work, make sure your connections are good if your using wire taps. Make sure you have the correct wire for + and - as well.
CivicsClass101
07-09-2015 11:14 AM
robbie374
07-07-2015 02:56 AM
