installed the RSX sway, have some issues now
Old Oct 7, 2005
ryangt's Avatar
ryangt is an unknown quantity at this point
Ok so i put the rsx-s sway bar on my 01 EX. Install went as smooth as can be expected, those end links with that hex head suck to remove. ok so the sway bar is on right, it isnt upside down or anything im sure of that.
first issue
some sort of weird little popping when im driving ( only thought it happened if the bar was on upside down.
second issue
my front tires seem to squeal alot when cornering at low speed.
theree was however a huge difference in handling with my sportlines and yellows i love it.
anyone have some input on these weird conditions?
Old Oct 7, 2005
chrisleecool's Avatar
hmm i'm about to install rsx sway too
I wonder what the problem is?...
Old Oct 7, 2005
mugenman's Avatar
"mmmBAHHHH" - vtec y0
is it a rear sway or a front sway?
Old Oct 7, 2005
ryangt's Avatar
rsx
this is the rear bar, the install was pretty straigh forward, i cant see any clearance issues so im stumped
it will be the best suspension upgrade for you well aside from some teins haha
Old Oct 7, 2005
cheukkin's Avatar
cheukkin is an unknown quantity at this point
no problem at all, everything straight forward to me and the hardest part is to deal with the endlink, It has 2 screws on the top and bottom that have to be remove in order to put the hang the sway bar there, and that's all it is, don't force to separate the ball joint or else in endlink you should be alright.
Old Oct 7, 2005
i used stock endlinks and there is no sound or problems just better cornering. maybe you need new tires.
Old Oct 7, 2005
skipbarber's Avatar
check your air pressure.
Old Oct 7, 2005
ryangt's Avatar
sway
i have newer ventus tires, like 90% tread on them, the tire pressure is at 35 psi
Old Oct 8, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
i saw in another post that the plastic cover(?) would catch the sway bar during cornering and needed to be shaved back.
Old Oct 8, 2005
TemjinX2's Avatar
you might want to check to see if your brushing are properly greased. I installed my front sway bar and i would get the popping sounds every once in awhile at low speeds. I re-applied some automotive grease between the brushing and bar and the popping went away.
Old Oct 8, 2005
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
Sorry, don't mean to jack the thread, but...
I'm going to be installing the rear sway bar soon too. Do you guys know what MM rachets i need to remove the bars?
Old Oct 8, 2005
K20me's Avatar
12mm socket, 14mm wrench, and a hex key.
Old Oct 8, 2005
ryangt's Avatar
OH ****, thats what i forgot, i didnt grease the poly urethane bushings, maybe thats what it is, im gonna give that a shot today and ill let you guys know.
anyone want pointers on the install let me know
OH YOULL NEED A PIPE HAHA
Rogelio Rey
May 24, 2015 08:30 PM
Youshoe
May 22, 2015 09:36 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Firefly
Nov 28, 2001 06:13 PM
