installed the RSX sway, have some issues now
Ok so i put the rsx-s sway bar on my 01 EX. Install went as smooth as can be expected, those end links with that hex head suck to remove. ok so the sway bar is on right, it isnt upside down or anything im sure of that.
first issue
some sort of weird little popping when im driving ( only thought it happened if the bar was on upside down.
second issue
my front tires seem to squeal alot when cornering at low speed.
theree was however a huge difference in handling with my sportlines and yellows i love it.
anyone have some input on these weird conditions?
first issue
second issue
rsx
this is the rear bar, the install was pretty straigh forward, i cant see any clearance issues so im stumped
it will be the best suspension upgrade for you well aside from some teins haha
no problem at all, everything straight forward to me and the hardest part is to deal with the endlink, It has 2 screws on the top and bottom that have to be remove in order to put the hang the sway bar there, and that's all it is, don't force to separate the ball joint or else in endlink you should be alright.
you might want to check to see if your brushing are properly greased. I installed my front sway bar and i would get the popping sounds every once in awhile at low speeds. I re-applied some automotive grease between the brushing and bar and the popping went away.
OH ****, thats what i forgot, i didnt grease the poly urethane bushings, maybe thats what it is, im gonna give that a shot today and ill let you guys know.
anyone want pointers on the install let me know
OH YOULL NEED A PIPE HAHA
Rogelio Rey
May 24, 2015 08:30 PM
Youshoe
May 22, 2015 09:36 PM
Dorval Andre
May 1, 2015 09:37 AM
