K20 w/ turbo
Retired - SoCal FI Mod
cybernation has a kit for our k20 swapped cars...
if you're gonna go with any other kit i think all of them would fit except that you would have to modify the exhausts....
Originally Posted by stl01civic
^^^ by any chance do you know if the greddy kit will work on k24a1 swaped???
Originally Posted by iamboo
the k24 is a bigger motor and it's a tight fit as it is... the tsx and the element and accord all have more room under the hood... it's highly doubtful that the greddy kit will bolt up but that doesn't mean a custom fabrication isn't out of the question... it might be cheaper if you know the right people...
I think on a custom kit for a swapped em2 (k24a1) would be a pain in @ss. think about that tight spot, you have to work with. not to mention the shop will kill you for the time it takes.
7thgen Power Maker
PM poorjayson
http://www.7thgencivic.com/forums/member.php?u=12232
He was the 1st 7thgen K20 swapped & boosted on a CN kit we sold him.
the best one i think is fullrace turbo kit for K20 its expensive but its worth it they use the GT35R turbo or you can use the GT30R best ball bearing turbo i think out there and its better than the greddy kit in my opinon. this kit cost from 4g's to 8g's
Its a celebration bitches!
the only diffrence between a k20 and k24 is 22mm higher in the block, so that means everything is the same, just 22mm higher. everything fits perfectly. almost everything on a k20 and k24 are interchangeable
HondaWhore
Mar 10, 2004 09:38 AM
