K20 w/ turbo
Old Sep 19, 2005
kornsined's Avatar
K20 w/ turbo
So what turbos fit in our k20 swapped engine bays with no modifications? I'm assuming a civic si kit.
Old Sep 19, 2005
iamboo's Avatar
Retired - SoCal FI Mod
cybernation has a kit for our k20 swapped cars...
if you're gonna go with any other kit i think all of them would fit except that you would have to modify the exhausts....
Old Sep 19, 2005
kornsined's Avatar
that's no real biggy modifying exhausts.
Old Sep 20, 2005
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
yeah i have the greddy kit on my swap and we didnt modifiy anything. well except fot the intercooler pipes.
Old Sep 20, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
^^^ by any chance do you know if the greddy kit will work on k24a1 swaped???
Old Sep 20, 2005
iamboo's Avatar
the k24 is a bigger motor and it's a tight fit as it is... the tsx and the element and accord all have more room under the hood... it's highly doubtful that the greddy kit will bolt up but that doesn't mean a custom fabrication isn't out of the question... it might be cheaper if you know the right people...
Old Sep 20, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I think on a custom kit for a swapped em2 (k24a1) would be a pain in @ss. think about that tight spot, you have to work with. not to mention the shop will kill you for the time it takes.
Old Sep 20, 2005
dezod's Avatar
7thgen Power Maker
PM poorjayson
http://www.7thgencivic.com/forums/member.php?u=12232
He was the 1st 7thgen K20 swapped & boosted on a CN kit we sold him.
Old Sep 20, 2005
jdmcivic01's Avatar
jdmcivic01 is an unknown quantity at this point
the best one i think is fullrace turbo kit for K20 its expensive but its worth it they use the GT35R turbo or you can use the GT30R best ball bearing turbo i think out there and its better than the greddy kit in my opinon. this kit cost from 4g's to 8g's
Old Oct 22, 2005
IceVic05's Avatar
IceVic05 is an unknown quantity at this point
how much power does the greddy turbo kit give vs like turbonetics?
cause ive read at turbo-kits (.com) that there is very little power given from greddy...
Old Oct 23, 2005
HondaLuver's Avatar
Its a celebration bitches!
the only diffrence between a k20 and k24 is 22mm higher in the block, so that means everything is the same, just 22mm higher. everything fits perfectly. almost everything on a k20 and k24 are interchangeable
justcruzin125
Aug 11, 2015 09:09 PM
dinglenuts
Engine Swaps
18
Nov 20, 2004 04:46 PM
2k5EP
Engine Swaps
Nov 18, 2004 07:47 PM
D-Vus CIV
Engine Swaps
Sep 12, 2004 01:16 AM
HondaWhore
Mar 10, 2004 09:38 AM
