k24a2 swap vs k20a2
French ass K20a2 powered
k24a2 swap vs k20a2
Ok... I ever swap myself a k20a2 in my car, So I gonna make a k24a2 swap for one of my friend soon...
I want to know if someone have the C101 connector wiring for the TSX (I only have Civic and RSX one).
And someone know if a k24 subframe gonna fit in an EM2 or I must found a k20 subframe.
So if I MUST know something about the difference in a k24 than a k20...don't be shy
Thank in advance...
Thank in advance...
Its a celebration bitches!
the wiring is the almost exactly the same as a rsx S. i used the k20 subframe. what car are you going to stick this in. with mine, i needed to customise the passanger side mount, the others fit perfectly
We gonna swap it in a Em2 with enjo mount (this kit is bolt on for k24 too)
Do you know if the intake manifold is bigger on a K24a2..?? everybody doing this swap seen to put the PRB or PRC head.
For the subframe... I don't know in the US... but in Canada found a used RSX or SiR (CDN Si) subframe is like a pain in the ***. But a Accord or CRV is pretty enough and really cheap. But we don't know if this gonna fit...
the intake manifold on a tsx, it has longer runners... i used a type R... its bigger, but i can't realy compare it... they put those heads for better flow and the cams.
use a base, type S or a Type R manual subframe. im not sure about those others
Ok so do you think the TSX intake gonna clear the engine bay near the hood sketch.... My k20a2 is only at 1/4 inches....A type R intake is a better choices ??
Thank for the subframe....we gonna search a k20 one
damn right it did.. i had it in my car... i had to fricken cut the frame by the radiator so it could fit... took that out and finally put in a different manifold... now i got a big cut right where the manifold used to be.. sucks ***... wish i just swapped out the manifold earlier
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
